Having my wheel alignment done at X Sport.
I checked the tires over before and quite thoroughly after Curby, didn't see a thing. So it's fairly recent.
About two days ago I noticed that when turning right it was making an odd ticking noise and the ESP was coming on. So I might have done it on a pot hole (can't recall going in one) or a flint or something within the last few days.
In terms of wear they were all really even and and only just below the limit, 1.5 at the lowest and 1.6 bang on across 2/3'rds on that particular tire, the rest were at about 1.8.
They do look fantastic on the car, and the grip is very very good.
There is lots of front end grip, and you can really get the fronts dug in and lift off oversteer if you want.
Neither Prawn or I have been brave enough to power oversteer the back end yet, it gets right on the cusp of letting go but the worry is that when it does neither of us have a clue what it will do. Hopefully with a bit more camber on the front and a bit more development in the chassis I will be able to get even more grip from the front.
I've ordered some Recaro Pole Positions (lols) and I just need to order some subframes on pay day, then harnesses to follow.
All coming together well.
Hilariously I fit a set of high contact track tires, and it rains for the first time in months!
