mattandrew
2004 A3 DSG
Ok here goes, last Sunday I decided to get all the parts needed to do the
DSG oil change. Picked the parts up Monday, filter etc.
On Tuesday I was driving to Warrington when the car started to surge, its
hard to explain, its as if the car was running out of fuel. It was as if its
losing drive. I had VAGCOM with me as a was travelling to N8KOV's so
pulled over and fault code checked the outcome is below. The surging is not permanent
It is not doing it all the time, I cleared the codes, with the ignition on
only the first fault came up, I then started the car and the second fault
came up.
I have just cleared the faults, (the engine was cold) and they
didn't reappear, drove around for 5 minutes and still no errors, then when all engine and box was warm the faults returned.
As anyone experienced this or heard of the problems??
I have checked previous services and the DSG oil change was carried out at 42k it has now done 67k
Address 02: Auto Trans Labels: 02E-300-0xx.LBL
Part No SW: 02E 300 041 C HW: 02E 927 770 G
Component: GSG DSG 0623
Coding: 0000020
Shop #: WSC 06435
2 Faults Found:
18148 - Clutch Temperature Monitoring
P1740 - 012 - Electrical Fault in Circuit
17100 - Transmission Input Speed Sensor (G182): Implausible Signal
P0716 - 000
I would also appreciate it if I don't get loads of replies slating the DSG
box in general
Thanks Matt
came up.
Coding: 0000020
Shop #: WSC 06435
2 Faults Found:
P0716 - 000
box in general
Thanks Matt
