Chris NottAH Fabrications
Results 1 to 18 of 18
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    Exclamation Immobalised Audi HELP!!
    Hello im new here.
    Basically i bought an Audi A4 B7 Cab about a week back, all running good no problems etc, until yesterday when a new Key Fob arrived. So i took it apart etc etc changed the key over and was trying to change the chip over but i couldnt so i just put i back together.
    I went out to unlock the car and the alarms and hazards were going off, key fob wasnt working atall tried re coding it and everything, had the AA out last night he couldnt do anything he recommended i take it to a Audi Dealership to get the key re coded. My friend who is a Mechanic mentioned something about if the battery is out of the fob for a over a certain time it loses its code.
    I know Audi will sting me for this tomorrow but i could really use some advice if possible, im sure someone must of had this problem or heard about it.
    Thanks Jason.
    johnnythepie's Avatar
    handcrankywannkyspanky
    Apr 2009
    Coventry
    2,174
    Have you had a bead at the owners manual, im sure when i had my B7 that it was explained in there, or look at this thread
    Recoding Key?
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    ive read the manual but it mentiosn about a 2nd key i dont have one .... i cant start the car so i cant try that method it just starts then cuts off within 2 seconds i will go try the first method but i think i have done it.
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    Just tried that method of the ignition lock and unlock and it doesnt work. alarm just went off and hazards are on really quick.
    1,887
    Have to say I would take it to Audi regardless if you can get it to start, and have them remove the missing key from the immobiliser.
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    do you know what kind of prices audi charge for labour. i really dont want to pay a ton just for them to plug it in re code the key fob. but i guess ill have to.
    1,887
    I guess your looking at Around £90 an hour labor rate but could be higher, depending where you live.
    Apr 2009
    Coventry
    2,174
    I think B5NUT is right in that youre best off taking it to audi to completely recode as you dont know who else has a key.I paid £200 last year to have a new key and new recode, but that was for a B8
    Pass me my sock
    26,776
    If it cuts out after few seconds then your little buggered, as either you've broken the immo chip capsule or got keys round wrong way, so either find correct part of fob that does start car or needs trailing/towing to dealer ideally as thats immo related & needs put on vas to fix ideally & I dont advise using alternative coders.
    Just remember immo & remote locking are 2 completely different systems, not linked at all, so immo needs doing aswell as remote, which audi would do anyway at same time.
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    Cars currently with Audi, so its now a waiting game. Cheers for your ideas and Advice
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    found of the problem. My master key had become defective, and because i dont have a spare i have to wait up to 5 days for a new key and fob to be made and sent from germany. depressing times
    North East
    568
    Quote Originally Posted by Jozzyy View Post
    Whats the forecast cost ?
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    He said about £200..£70 for the key £80 for the new Fob and £50 for recoding it.
    North East
    568
    The cost for my Honda Civic three years ago was £350 so I guess at todays prices its not too bad !
    26,776
    If it was working fine before dismantling, then imho the immo chip was damaged whilst doing, if its a megamos 48 then the glass capsule is very delicate & can get broken very easily.
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    It could possibly be that then. oh well its done now and my Credit card will soon know about it.
    Apr 2012
    N. Wales, LL22
    1,224
    those glass capsules are a pig to do, when i redid my passat keys i cut the key from round the capsule rather than lever it out
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Maskwelli's Avatar
    Jan 2013
    Buckinghamshire
    46
    haha thats another way of doing it
  1. Non-audi help needed
    By way318 in forum General Automotive Chat
    Last Post: 3rd March 2011, 22:12
  2. looking for ipod interface for my audi..help!
    By audi_a3 in forum In-Car Entertainment
    Last Post: 17th January 2011, 01:31
  3. Incomplete service history - can audi help?
    By Minstadave in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2010, 20:02
  4. 1st Audi HELP!
    By audipar in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th February 2009, 22:11
  5. Newbie to Audi...help please
    By imported_WRX2A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd September 2004, 07:52
