Monster MotorsportChris Nott
Results 1 to 13 of 13
    i_786_i's Avatar
    Aug 2012
    57
    Pro Scan V400 Diagnostic Tool
    Just purchased this VW/AUDI diagnostic tool to scan my car for any codes.
    It doesn't have the MIL light on, but wanted to make sure that none of the other systems had any fault codes.
    Simple to use - ran a test by removing a switch, which did present an error and then was able to easily erase the error, bringing it back to normal again
    Cheap to purchase and great for keeping car in check.
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    How much and where from?
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    i_786_i's Avatar
    Aug 2012
    57
    I got mine from ebay item number: 120935999839
    Only cost £30+pp and has 1-yr guarantee so that's good for me.
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,077
    What year is your car? I'm asking because I was under the impression most of the cheaper scanners don't work with newer CAN-Bus cars but I don't know when this change happened (my car is a '57 plate). I'd love to get one as they are a handy tool to have but can't afford VDCS.
    i_786_i's Avatar
    Aug 2012
    57
    2006 B7, not all features are compatible with my model (e.g service reset- but I can do this manually anyhow)
    It says its compatible with 2001+ cars and will be trying it on a few cars and keep you posted, but it reads instantly and does the job.
    27,099
    This is not vagcom & you shouldnt badge it as, vagcom is vcds & only available from RT & there distributors/resellers.
    i_786_i's Avatar
    Aug 2012
    57
    Sorry about this, didn't realise VAGCOM was a trademark or similar. It should be corrected now
    jakeriddler's Avatar
    Sep 2006
    Yorkshire
    23
    I just thought (as I just bought one ) - does erasing codes mean anything bad, or should they be reset?
    Im worried that if I erase the code it may do more than just reset the problem (in my case turning off the airbag & abs lights)
    Any thoughts welcome
    i_786_i's Avatar
    Aug 2012
    57
    Quote Originally Posted by jakeriddler View Post
    Hi, All the erasing does is reset the fault. If the fault remains the error may be displayed again. Shouldn't have any other issues by a simple reset.
    Sep 2006
    Yorkshire
    23
    Thank you for that mate, I wasnt sure if it would do more damage & if the 'erase' was a more serious sticking head in sand solution than 'resetting' (which wasnt an option
    Ill see how I get on
    Oct 2012
    Hi I also have just purchased this scanner, do you or anyone else know what web site you go to to update the unit as the oil reset is not supported for my car everything else works fine. Also who manufactures the ProScan V400 CAN VW/AUDI . I can not find any info at all, plenty places to buy one but no real info
    Paul
    i_786_i's Avatar
    Aug 2012
    57
    Hi,
    You need to email the company on the following addresses:
    support@pr​oscan-autom​otive.com
    updates@proscan-automotive.com
    help@proscan-automotive.com
    They will add you to their database and email you once an update is available.
    Oct 2012
    Many thanks for details, I will email them now
    Paul
  1. vagcom scan needed in nottingham city area £20 for your help?
    By syski999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2011, 07:02
  2. vagcom scan!!!
    By housey11 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2010, 08:56
  3. Help with VAGCOM scan. EGR System
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2009, 20:03
  4. Vagcom scan in Cheshire
    By Morzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2009, 20:14
Tags for this Thread
