Sky InsuranceEM Tuning
Results 1 to 11 of 11
    May 2012
    87
    oil pump replacement
    hi
    does anyone know if i need a different sump cover if you change from a chain driven unit to a geard unit?
    thanks
    North East
    568
    Quote Originally Posted by hubbo1 View Post
    hi
    thanks
    Yes, you need a new sump cover.
    May 2012
    87
    thanks
    Jun 2012
    9
    What do you mean by sump cover?
    North East
    568
    Quote Originally Posted by Chris Shepherd View Post
    When Audi convert the chain driven oil pump balance shaft assy to a geared unit they fit a new sump /sump cover to accomodate the new assembly. The existing sump/sump cover will not fit over the new geared assembly.
    Jun 2012
    9
    Bugger, more bits to buy. I'm trying to gather the bits together to do the conversion, I love the car to bits and I'm not letting an issue like this dishearten me and being an ex truck mechanic and my mate having his own vehicle lifts it's not going to be hard to do.
    North East
    568
    If you trawl through the "sticky" on the 2.0tdi oil pump/balance shaft issues you will find people have posted lists of the parts needed to do the conversion.
    Its a LONG list so be warned.
    Paul B
    May 2012
    87
    hi paul, had my pump/balancer changed at local indi-it didnt need a new sump,maybe its just a dealer thing?
    pump change (i supplied),cam belt and water pump,oil and filters,transmission and final drive fluid change,aircon re-gassed,diagnostic.
    total cost £800.
    ps pump was second hand from volksbreakers with warranty-£400
    North East
    568
    total cost £800.
    The new sump cover is only needed when replacing the chain driven oil pump /balance shaft assembly for a geared unit.
    I guess you were replacing the geared unit on a like for like basis, hence you didn't need a new sump cover.
    North East
    568
    Quote Originally Posted by Paul B7 View Post
    This is the part number for the new sump, V03G 103 603h Oil Pan at £92.01p
    The price being from late 2011 when I had my car fixed by Audi Teesside.
    May 2012
    87
    i had the chain driven pump swapped for a gear driven one-the sump went on with no problem.
    i did ask a few indipendents about this and all said it didnt need a new sump-as i said maybe its a main dealer thing-squeezing all they can!
  1. oil pump replacement
    By hubbo1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th August 2013, 16:37
  2. oil pump replacement question
    Last Post: 27th June 2012, 21:56
  3. Audi S3 replace oil pump
    By Agric04 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2011, 08:10
  4. Is it worth me replacing the oil pump strainer?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 20:30
  5. Replacing oil pump!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th August 2008, 19:31
