Monster MotorsportEM Tuning
Page 5 of 15 FirstFirst 123456789101112 ... LastLast
Results 161 to 200 of 569
Like Tree81Likes
Thread: Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
  1. #161
    Dec 2012
    33
    Up
  3. #162
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    361
    Quote Originally Posted by Arcer View Post
    Hi all,
    Excuse me for my english
    I've the same problem described in this thread, month ago i've pulled out my electric motor, cleaned the brushes and all work fine. Recently the problem come back again, I've pulled out again the electric motor and did the same things, but the roof not work.
    I have noticed that there is a brush that is completely locked, while the other is free to move.
    Must move both?
    how do I unlock it?
    how can I make sure it gets electricity to the motor?
    how do I place the multimeter?
    How can I accept myself that the motor is not completely broken?
    by scanning with vag not find errors in the form of the roof
    thank you all
    HI arcer
    All of these questions are answered previously on this thread see gaz 2nd nov 2012
    Brush must be free to move
    open the brush carrier by prying it open to loosen it
    connect the multimeter to the two wires going to the motor but you have to reassemble the storage compartment and close boot to be able to test
    If freeing the brushes does not work and the motor is getting power then you need a new one £180 from Audi
    you will not find any error codes for this issue
  4. #163
    Jan 2013
    ive got to say that you saved me over 2k. my hood was not closing so i printed out your procedure and gave it to the dealer. they refused to follow it at first and said it would cost 2.5k to repair. then when i told them to take out the motor so i could do it myself they did it for £300!!! thank you so much!!!!! made me realise how much they can con you. always thought you could trust a dealer but clearly you cant.
    VagPro likes this.
  5. #164
    Feb 2011
    361
    Quote Originally Posted by audijon View Post
    Hi audijon,
    Probably the one of best pieces of feedback I've had on this topic!! Glad to know I've helped another fellow member. Just make sure that they have pried open the brush carriers or the problem will reoccur. Out of interest which dealership was it ? I should probably ask them for a job lol !
    Enjoy the sun (!) when it arrives
  6. #165
    Jan 2013
    hi there,
    probably best i dont give the dealers name. lets just say they are in north cambs.
    regards,
    jon
    VagPro likes this.
  7. #166
    Feb 2013
    hi i have a56 reg a4 cab and the roof works the odd time now but most of the time says soft top cant be opend on dash..there is no motor noise so just wondering will the motar need cleaning or replacing for soft top?..can any any one help please
  8. #167
    Dec 2011
    Glasgow
    195
    Quote Originally Posted by taz5431 View Post
    You need to scan the car with VCDS to see if there are any faults listed for the roof sometimes the sensors go faulty so it stops the roof working
    If there are no faults listed Chances are its the motor. You need to gain access to the motor and check if your getting a voltage at the motor connections if you are chances are its the brushes on the motor
    You need to follow the steps listed in previous threads to fix and clean the brushes of the motor
    VagPro likes this.
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
  9. #168
    Feb 2013
    Thanks for this excellent post & so helpful
    VagPro likes this.
  10. #169
    KO
    Mar 2013
    Hi, unfortunately the roof on my wifes 56 reg A4 also has this fault where it unlatches and raises a few cm but goes no further - although it can then close again automatically from that position. In an effort to avoid getting ripped off by main dealer I took it to an independent who scanned faults and told me that the microswitch in the front locking motor assembly was intermittently failing, they quoted me £243 to replace. I already had my doubts about whether this would be the full story and after reading through all of these posts I wonder if there is nothing wrong with the switch and the fault actually lies with the pump motor. It appears to me that this is a much more common fault, but why would the diags indicate the switch as being faulty? Also, if it was the switch can anyone confirm if this can be replaced, as I thought it was an integral part of the front motor assy.
    What would be the easiest way to check which of these is causing the fault or do you guys think it may be something else?
    Thanks for any help guys.
  11. #170
    Feb 2011
    361
    Talking
    Quote Originally Posted by KO View Post
    Hi KO,
    Sounds like its the motor fault, I've just repaired another last weekend. When the roof doesn't complete a full open close cycle this can trigger fault codes for the various switches giving "implausible" signals. According to the wiring diagram (in the main guide) there are two switches and they should be replaceable if not a minimum serviceable. Did he clear the codes and see if they reappeared? Did he check the switch measuring block values ?
    If you have vagcom I can tell you how to check the switches in measuring blocks, if not you can use a multimeter to see if the motor is getting current or if the switches are faulty.
    P.s. forget independents, even dealers have been wrong !!
  12. #171
    KO
    Mar 2013
    Hi Krumz,
    I don't have vagcom but a friend at work may have. For now I think I'll check with a multimeter. I take it I need to run a couple of wires from the motor terminals, out of the closed boot to a multimeter and then try to open roof. I guess I should not have a reading until the phase just after the roof unlatches and then read 12V DC?? If I do but nothing else happens does this prove that it is the motor? If I don't is there a fuse I should check?
    (By the way, fantastic initial post mate.)
  13. #172
    Feb 2011
    361
    Hi Krumz,
    cheers for the feedback
    yes too all of the questions above, there are a few fuses, check the wiring diagrams I've posted on page 1.
    You may be able to even get away with giving the motor a few taps to free the brushes and then test it. Words of advice, there is a clip holding down the boot side cover which you can get to by opening the convertible roof storage compartment, if it is the motor, don't forget to pry open the brush carriers to let the brushes move freely. And finally if it works, print of a copy and give it to your independent dealer
  14. #173
    KO
    Mar 2013
    Thanks for the tip. Hopefully I'll get a chance to check it out this weekend. I'll let you know how I get on. Thanks again.
    VagPro likes this.
  15. #174
    Feb 2013
    Audi A4 Cabriolet convertible 2008 58 reg 2.0L TDI S Line roof soft top issues - roof won't fold down and only moves a couples of inches then stops or is stuck. I looked at the hydraulic level on the pump reservoir - it was fine, I then thought I would check the brushes for wear, so I re-opened up the hydraulic motor pump assembly for the soft top & tested the brushes on the commutator to make sure there was plenty of wear left & I found one of them sticking in it's brass housing! so here's what I did...I got very small flat screw driver to slightly prize open the top gap on brass housing on the brush unit, the small brush immediately sprang out to touch the commutator unit, I tested it (its spring loaded) several times before putting the motor etc. back into place the roof now works fine.
    Audi Newcastle wanted £600 to investigate & repair or replace the unit...
    cheers, Micky Bell - Blyth, Northumberland.
    VagPro likes this.
  16. #175
    Feb 2013
    Just figured out how to post my issue on the forum - see above
    VagPro likes this.
  17. #176
    KO
    Mar 2013
    Thanks a million Krumz. The roof is sorted and the wife is delighted!
    One brush was sticking badly - I freed it with WD40 and pryed the carrier open a bit, as you suggested.
    I also thought it was worth cleaning the faces of the brushes with wet and dry. Cotton wool buds were helpful when cleaning the commutator. Hopefully the repair will last, but even if it doesn't I am glad I know for sure what the cause of the fault is.
    If anyone else is experiencing the same issue I would strongly suggest that they keep their wallets in their pockets and follow the advice given in this thread - it is not very difficult and will save you a fortune.
    It certainly seems to be a common issue (although the independent I went to failed to suggest it as a possibility)
    VagPro likes this.
  18. #177
    Feb 2012
    Alternate source of fault
    For anyone out there, I had the same issue as the initial poster with a 2003 A4, top unlatched, rear lifts but storage panel unlatches then stalls, basically doesn't lift more than an inch or so.
    After following motor bush refurb guide, even purchased 2nd hand motor to eliminate, re sync'd, plugged into VAG diagnostic with similar codes to others, all resulted in no improvement.
    It finally turned out that one of the motors/guides**? had worked loose, this sits within the narrow front panel situated directly above the head of the driver when the roof is initially unlatched.
    (**it was with the mechanic by this stage who explained, so terminology may not be correct)
    The mechanic identified that a grommet/bush had worn along with a very slight movement of the mechanism (again within the same front panel), enough to cause the issue in his view.
    With new reworked bush/grommet and retightening the roof works perfectly since.
    If nothing else I hope it helps someone out there to look in this area if all else fails.
    Great thread for the enthusiast, Thanks for posting.
    VagPro likes this.
  19. #178
    Jun 2011
    Borehamwood
    Quote Originally Posted by VagPro View Post
    Jay,I opened mine up over the weekend and found the same problem again (dirty commutator). When checking the brushes I found that one of the brushes was not moving freely in the carrier, leading to poor contact and in turn more arcing. I have since then put a drop of WD 40 on the brush carrier and worked it free. (See white arrow)
    Hi Krumz, unfortunately I too have just developed this dreaded issue on my A4! Looking at your fantastic write up, I am going to attempt it this weekend! I just wanted to clarify how to free up the brushes... Once you drop the WD40 in the carrier, do you pry the brushes free with a screwdriver or does this cause damage to the brushes in the carrier?
  20. #179
    Feb 2011
    361
    Quote Originally Posted by del1407 View Post
    Hi Del,
    Yes pry the brush carriers with a small screwdriver, as long as it does not contact the brushes you will not damage them, or they will get stuck again.
  21. #180
    Apr 2013
    lancaster
    17
    hi great write up, i have just joined and in need off help with my roof, when i press the down button the windows drop half way and the front upper roof will open but thats its, i have the launch diagun and if i clear all codes and then try it again the codes that come back are 00532 supply voltage and 02023 terminal 87 , i do hope someone can help me with this problam as its doing my head in lol cheers in advance
  22. #181
    Apr 2013
    25
    I cannot thank you enough. Im looking at a quote from Audi for £2353.22 for replacing the hydraulic pump. I thought, it cannot cost that much and stumbled across this thread.
    Well i cleaned the commutator Saturday and the roof went down, brilliant - but then would not go back up.
    Today i took the pump out again and this time took the actual electric part off, make for easier cleaning. I could also clean the brushes and oil them as they were no longer springy. When i went to clean the excess oil away with lighter fluid, you would not believe the amount of carbon deposit that i got off - this really was the problem with the pump after all.
    Its a shame that mechanics who fault find are a thing of the past and technicians just want to replace a whole pump just because a computer tells them too.
    This whole operation over the two days took me about 2-3 hours or cleaning etc, not a bad hourly rate hey.
    Thanks again, ill ost some extra pics which you might find helpful.
    Warren
    VagPro likes this.
  23. #182
    Apr 2013
    25
    A before and after the first clean. You can see the black carbon buildup on the before pic (left).
    dirty_clean.jpgCLICK ON TEH PICT TO GET A LARGER VIEW
    I took the electrical part off to make it easier to clean, heres whats inside after removing the two bolts.
    BEWARE, THERE IS OIL IN HERE AND YOU HAVE TO PLACE THE PUMP SO THAT NONE SPILLS OUT
    And cleaning these so the spring again (they just stayed in when pushed into the housing) is what worked for me.
    Thankyou thankyou thankyou
    Warren
  24. #183
    Apr 2013
    25
    Sorry to keep posting. But if anyone in the South London/Surrey area wants a hand with this, im happy to help.
  25. #184
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Good result, nice to hear this thread has saved you £££.
    My friends wife's 07 cabs roof has failed so hopefully this will work too.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
  26. #185
    Feb 2011
    361
    Quote Originally Posted by cossiedave View Post
    Hi Cossiedave,
    I have not come across this before. Check the wiring diagrams at the beginning of this post, you may not be getting power? Have you checked all the fuses.
  27. #186
    Feb 2011
    361
    Quote Originally Posted by wobblewoo View Post
    Warren
    Hello Warren, thanks for the feedback and glad this post was useful, may I just add that (for the benefit of other users) removing the motor from the hydraulic assembly is not necessary (to avoid spilling oil) and you may choose to pry open the brush carriers with a small screw driver to allow the brushes to spring back freely.
    P.S. you could always go back to Audi and teach them something they dont know
  28. #187
    Apr 2013
    lancaster
    17
    Hi roof now working, ran another feed to the control module and hey presto it worked, rear boot still don't open on remote and drivers seat still doesn't do any thing but well chuffed roof is working
  29. #188
    Feb 2011
    361
    Sounds like a power issue, what is your year, engine and gbox code and I will post the Base Equipment wiring diagrams for you
  30. #189
    Apr 2013
    lancaster
    17
    thanks mate its 2002,2.4 v6 with multitronon box, i have the latest auto data disc, i carnt get the seat to move to get the bolts out lol
  31. #190
    Feb 2011
    361
    Hi need engine code and gearbox code, youll find these on a sticker in the spare wheel compartment
  32. #191
    Apr 2013
    lancaster
    17
  33. #192
    Feb 2011
    361
    Hi Cossiedave,
    Link to wiring diagram for roof below,
    Wiring Diagram
    Follow which wire should have the power and see if you can find where there problem is, I personally would not recommend running live feeds to control modules.
  34. #193
    Apr 2013
    lancaster
    17
    ok cheers mate i will take a look ta
  35. #194
    Dec 2012
    33
    Vagpro can you take a video :P???
  36. #195
    Feb 2011
    361
    Hi arcer, I'm sorry I cannot open my motor again to take video, there is a detailed step by step guide on page one of this thread.
  37. #196
    Apr 2013
    25
    Well the sun was out yesterday and i put the roof down at lunch with no problems, however when i went home it stopped working.
    I guess i will have to strip it all down again and prise the brush carriers apart a bit, i didn't do that last time.
    Does that fact that it worked for a while probably mean its ok?
    I will go and run a scan with my vagcom at lunch and see what it shows. Was there any extra tests i can run to test the roof?"
    W
  38. #197
    Feb 2011
    361
    W
    Hi Warrren, prying apart the carriers should stop the problem reoccurring, let me know how you get on and if you need anything drop me a line.
  39. #198
    Apr 2013
    25
    Ill pry the carriers apart and get back to you. In the meantime, heres relevant scan data if you spot anything untoward, could you let me know please?
    Address 26: Auto Roof Labels: 8H0-959-255.lbl
    Control Module Part Number: 8H0 959 255 A
    Component and/or Version: VSG B6 CABRIO 6894
    Software Coding:
    Work Shop Code: WSC 00672 785 00200
    VCID: 346D6D74542070E
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    And if i measure blocks, heres the log:
    Address 26: Auto Roof (8H0 959 255 A)
    13:36:36 Group 001: Convertible Top Status (Actual)
    Not Oper. Convertible Top Control Switch
    11011010 Switches && Positions I
    10 1010 Switches && Positions II
    230.0 Top Frame Position (G356)
    13:36:36 Group 002
    0.0 km/h Vehicle Speed
    11.70 V Voltage (Terminal 30)
    Lid close Rear Lid Contact Switch
    00000000 Window Regulator Operation
    13:36:36 Group 003: Window Positions
    0.5 Window Position Driver's Door
    0.0 Window Position Passenger Door
    0.0 Window Position Rear Left Door
    0.0 Window Position Rear Right Door
    13:37:34 Group 001: Convertible Top Status (Actual)
    11000110 Switches && Positions I
    227.0 Top Frame Position (G356)
    13:37:34 Group 002
    11.60 V Voltage (Terminal 30)
    10101010 Window Regulator Operation
    13:37:34 Group 003: Window Positions
    45.5 Window Position Driver's Door
    46.5 Window Position Passenger Door
    58.0 Window Position Rear Left Door
    57.0 Window Position Rear Right Door
    VagPro likes this.
  40. #199
    Dec 2012
    33
    Last sunday I've unlocked soft top of my car....but still have not figured out where to put the screwdriver to pry. Ok in brush carrier but WHERE???
  41. #200
    Feb 2011
    361
    Arcer,
    Page 1 there is a picture with a white arrow further down, you will see there is a slot in the brush carrier for the cable, use a small screwdriver and pry it open from there. Then check the brushes are moving freely.
  1. Audi A4 Cabriolet Hood Problem
    By vaslam1986 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th July 2010, 01:58
  2. Audi Cabriolet - Manual Hood Problem
    By AllDubbedUp in forum Classic Audi Forum
    Last Post: 21st February 2008, 08:50
  3. Cleaning/Protecting Soft Top Roof...?
    By Katherine B in forum Detailing
    Last Post: 7th March 2007, 10:18
  4. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
