Key Fob question
nosaj
Essex, Near Marks Tey
Well collected the new car today
it has 2 key fobs , and was told the second one needed a new battery
sometimes my old vw one was like this but
on replacing it with a new one
it still doesnt work
now i have tried doing the reprogram that the manual says ......with no luck
i have also done a big search on the net
and found about 6 difrent way to reprogram
tried them all with no luck
anyone help out on this ,
Hi nosaj
That sucks m8, u have probably tried this but here goes, press fob and imediatley stick the key into the drivers lock,turn left/right and leave key for a minute, take key out and try.
Silly thought but have u tried swapping the fob batteries around, at least to eliminate this?
Hope u get this sorted m8
Cheers J
pop the keyfob apart and check the really small print, it will show the frequency numbers, they are 4.34 mhz or something like it, check that both fobs are the same mate.
Hi nosaj
Cheers J
cheers
will try that in the moring
didnt wana swap batteries over case other remote losses programming
will that happen if i do that ????
Hi nosaj
Best to try everything before removing the "good" fob battery,just incase.
Does manually inserting the "broken" fob into the door open/close it?
Can you start the engine with it?
Try puting the key in drivers door and open then put key into egnition and turn ignition on/off a couple of times then press lock on the fob.
Did you get the plastic key or the plastic tag when u purchased the car?
Cheers J
Hi Nosaj
Did you manage to get the fob to work?
Cheers J
still no luck , but i have a mate who is going to check with vag com that the car is seeing the key ,
then he will programme it hopfully
will keep ya informed
Hi jason
That is the best route to go down,you should be able to resync the fob via the car, but the immobaliser will need vag.com and the plastic tag you should have got wiht the car will have a four digit code on it.
I came across a detailed account of "howto" re-sync the fob to get it working , so if you want PM me and ill forward you the info.But if you wanna wait till your mate comes, then hope u get it fixed.
Hope u get it sorted
Cheers J
800
651
7
2K
907
