EM TuningJMB Retrofits
Results 1 to 8 of 8
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    Question Opening ROOF - how fast would you go?
    Hi - What speed would you say you'd be comfortable driving whilst opening or closing the roof?
    (I know its restricted to something like 5mph but but i'm now able to drive upto 25mph whilst doing so!)
    Its factory obviously fitted to 5mph for a reason but I'm interested in what others would be comfortable at. And what sort of damage could arise if I was silly enough to drive at 25mph, against the wind! Cheers
    Aug 2004
    Aberdeenshire
    740
    I probably wouldn't go above 10mph. The last think you want it to be driving aruond with a knackered half open roof when it's pouring.
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    I wouldnt want to be moving at all whilst opening & closing to be honest! Stick you face in the wind at 25mph and see what it does, you've got to be mad to try opening & closing the roof at that sort of speed!!
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    I understand what your saying... but think about this:
    If you open the roof whilst stationary and the car is facing a 15mph wind (Beauford scale - moderate breeze - Raises dust and loose paper; small branches are moved). Would you think twice?!
    colemanlee76's Avatar
    Suspicious
    Aug 2006
    Kent
    117
    I think you should write to Brainiac and see if they are willing to experiment, I personally think the question is pointless .
    If Audi restrict the car to 5mph then I think, reading between the lines, they want you to stop the car to open the roof.
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    The B7 roof will operate at up to 20mph so I wouldn't worry. Do you seriously think Audi haven't tested for every eventuality, I've opened and closed mine while driving along no problems.
    The only stupid thing is if your opening/closing and go over that speed it just stops the mechanism wherever it is in its position often turning you into a land sail...
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    Quote Originally Posted by Cupramax
    That's reasuring - I didn't know that, many thanks
    I don't think there would be any changes between the B6 and B7 regarding the roof mechanism - its only the rear lights and front that changed.
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    Thumbs up
    It does operate quicker on the B7 as well, I dont think there were any physical changes to the roof frame, just quicker motors.
