Monster MotorsportChris Nott
Results 1 to 17 of 17
    Sep 2011
    30
    EGR Blanking....
    Hi folks,
    Just purchased a 2004 1.9TDI A4, and reading up here found some useful things i wanna do, could someone give me a 'how to' on going about blanking the egr valve please?
    Chris
    Jul 2011
    102
    There is a thread here somewhere, I've just searched for it yesterday. I've ordered the blank of the bay and I believe you simply undo the egr mounting bolts and slip the plate between the valve and the pipe, then put the bolts back in.
    2002 A4 1.9TDI Avant SE Quattro
    Revo remap
    Rotalla tyres
    Sep 2010
    stoke on trent
    37
    Don't blank it get rid of it.
    Sep 2011
    30
    any how to's on a 1.9tdi???
    Jul 2011
    102
    Quote Originally Posted by bradster View Post
    Does it make any difference to the car whether I blank it or get rid of it?
    Hang on, if I get rid of it, I still have to blank it dont I......what is the difference?
    Revo remap
    Rotalla tyres
    Sep 2010
    stoke on trent
    37
    Hi I removed egr and replaced with allard pipe , it looks neater and when blanked not in use anyway and with allard pipe you haven't got all the crap like in the egr to restrict air flow.
    And yes still have to use blank plate .
    Bradster
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    199
    Guys if this is blanked off, or removed for an Allard one, wont this throw a warning light up on the dash, which can fail M.O.T?
    Im curios too as i have been thinking about blanking it off, Mines an 04 plate if that makes any difference.
    Ross, MK4 Golf - R19 DUB, B6 Avant - R19 RRW
    mikeh126's Avatar
    Preston, UK
    152
    Quote Originally Posted by rawtor51 View Post
    It will only upset the ECU if it's an electronic EGR valve.
    AFAIK, all B6's have a manual (ie controlled by a vacuum pipe) EGR - so no lights on the dash if it's tampered with, disconnected, or blanked off.
    I believe the later (ie B7's) have an electronic EGR. Blanking them off would also need the ECU re-programming to stop the engine management light coming on.
    2003 A4 Avant 2.5TDi 180 Quattro Sport in Light Metallic Silver, Remapped to 220 by ProTec Motorsport, RS4 18" x 8J reps, Falken F452 tyres, 10mm H+R Spacers, Matt Aluminium Mirror Covers, Heated Mirrors, S4 Door Blades, Continental TS830p Winter Tyres on 5 star 17" Sport Alloys
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    199
    Sweet , thanks for that
    Widemonkeys's Avatar
    Aug 2010
    Durham, Durham, United Kingdom
    274
    Has anyone got a guide for blanking or installing the allard pipe
    02 A4 B6 1.9tdi Avant sport 130bhp, 18" RS4's, Cruise control, Armrest, Ambiant lights, LED number plate bulbs,Pressed number plates, rear RS4 ARB, blacked out grills.
    Wanted : S line front and rear bumpers , S4 lower grill, s4 door blades
    Sep 2010
    stoke on trent
    37
    Got allard pipe of eBay for around about £50 every think you want to do job plus instructions
    Dec 2010
    Huddersfield
    30
    Not true, The light came on on my 2003 B6 2.5tdi v6 after being blanked but it came after only removing the vacuum pipe first before I had time to blankl the egr.
    Apr 2011
    Ross-on-Wye
    26
    same here blanked mine with a forge one light been on for 6 months now 03 130 tdi b6.
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    199
    right so one came on when you pulled the vac hose then blanked it, and one just came on, Can anyone else confirm if the light comes on or not if i just put in a blank and leave the vac hose alone.
    Thanks folks.
    mikeh126's Avatar
    Preston, UK
    152
    I have the pipe blanked off, and the engine management light hasn't been, nor is it on, now.
    A good friend of mine is a qualified auto electrician, with his own auto electrical business. The info I posted earlier about vacuum EGR valves, and later electronic EGR valves came from him. He said: "If there are no electrical connectors to the EGR valve, and no sensors, the light shouldn't come on".
    My 2003 2.5TDi (AKE) has the vacuum EGR valve, and the light has never been on, either with the vacuum pipe disconnected, or with the blanking plate fitted. Having said that, there are posters on here who have had the light come on after interfering with the EGR. So, I'm confused as well.
    Hope that helps!
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    199
    Thumbs up
    It does yes thanks, at least I know if its not electric it should be fine. Cheers.
    Dec 2010
    Huddersfield
    30
    Quote Originally Posted by mikeh126 View Post
    Hope that helps!
    My car is same model and same age but my engine code is BAU so maybe that is the difference....
  1. Blanking egr on 2.5
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2011, 17:33
  2. EGR blanking plates
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2011, 09:01
  3. egr blanking
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2010, 22:43
  4. blanking plate!
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2007, 21:07
  5. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
