AH FabricationsChris Nott
Page 8 of 8 FirstFirst 12345678
Results 281 to 313 of 313
Like Tree3Likes
Thread: Coming Home & Leaving Home Lights Enabled
  1. #281
    rdfcpete's Avatar
    Apr 2008
    117
    Quote Originally Posted by waring192 View Post
    I have a similar problem, when DRL's are on the headlights are on also? I can also go from dip to main while in that mode. Is there anyway too stop this without getting rid of the mod?
    Cruiser,
    Out of interest did the leaving home/coming home mod with the wire work for you (putting the described issue aside)? You're the only person on the thread that visually & obviously has an 8P3 2009+ car that appears to have attempted it so hope you don't mind me inquiring Cheers.
  3. #282
    Boon's Avatar
    Sep 2012
    South East Kent
    342
    Many thanks for your guide, it has worked a treat
    54 plate A3 sportback, No light pack, No light/rain sensor (auto lights)
    Checked the settings in VCDS then earthed pin 12 in block E with a quick touch and left the wire tucked inside with the fuses to add a push to make switch at some time for when the battery has been disconnected and if it needs that quick re-earth tap
    Now on to the other issues...... Haha....
  4. #283
    luton
    234
    Alright guys , tried this earlier on my 53 plate with mo
    joy, the lights flash on and off for about a half a second then go off,
    Any ideas ? Mines a 53 plate a3 btw, could it be the timing has been set to short for it with vcds?
  5. #284
    Jan 2012
    1,601
    Quote Originally Posted by danny_s3 View Post
    Yep try your settings in vcds - I have mine set to 15 seconds coming and leaving home.
  6. #285
    luton
    234
    After much messing around , following the guide , trying on my a3 and my mates I have had no joy ,
    Would anybody in the Luton or London area be interested in helping me if I brought my car to them
  7. #286
    rdfcpete's Avatar
    Apr 2008
    117
    Has anyone tried this on the 8P3 A3 (2010 and later) yet with reliable results?
    Welcome to try on mine (2010 A3 BE 2.0 TDI 170ps) as an example car if anyone fancies it from a trial & error point of view to make sure I don't miss anything
  8. #287
    Feb 2013
    Sheffield
    I'm the same as rdfcpete - I have just got my A3 BE (62 plate), I'm based in Sheffield and if anyone wants to test setting CH/LH lights I'd be happy to let them loose on the car. If anyone know's how to do the mod on post 10 plate A3's I'd appreciate it if I could have their contact details, preferably based in the North!
  9. #288
    Sep 2012
    Prague, CZ
    88
    The ch/lh is only headlights on pre my10 cars & then changes to fogs, so atm I'm unaware of any coding that changes this.
    @NHN - Is this still the case?
    I've tried various different coding options and still my Xenon's come on instead of just Fogs & LED DRLs.
    CE is 8P0 907 279 N on my 2009 plate 8P3, I'm running the latest VCDS, not sure if there is a newer label file available to show more options?
    I've searched the forum high and low for an answer to this but have had no success.
  10. #289
    -adrian-'s Avatar
    .fuct
    Apr 2012
    Northampton
    59
    Hi, cant really read the whole thread. got that problem: 00216 - Signal EC-mirror Fade Out 009 - Open or Short to GroundIs this part of the other error code with plus on light detection sensor? i had it wired as requested.. now the wire just hangs around somewhere. should i remove it or leave it hanging around and what is that error code?I also have the feeling my sound system has a earth problem - could it be this one? even though music is off it sounds like there is some "tension" on the speakers.Oh and why i actually wanted to post as well:bit 5 and 7 are set but for some reason the light goes just on when i leave the car, close it per remote and open it per remote again. then the light will go on. should it go on with door opening as well? because i have the feeling it just uses it as leaving home light(edit: i actually found the position with the error codes. still not satisfied with the fact the ch/lh just works sometimes. would a useless workaround if its not actually working around :O so stop teasing this function would "work" without sensor got me all excited
  11. #290
    Mar 2013
    11
    where would you get the repair wire from if you didnt already have it?
    cheers
  12. #291
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Audi. I got a couple the other day
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
  13. #292
    Dec 2012
    19
    Quote Originally Posted by boggym View Post
    The 4 wires going to T6j connect directly, and only, to the coming home button on the light switch. T6j/1 goes to earth. I'm not dead sure where T6j/4 and T6j/2 come from but one supplies the switch with the power for the small light that is permanently on (similar to the light for the main light switch) the other, I would assume, comes from light sensor to tell the set up whether its day or night. T6j/3 goes to the pin 12 of connector E. With Marc's wiring, he's basically bypassed the switch and connected earth straight to E12, thus enabling a permanent, non-switched connection.
    I've retro fitted a new light switch with the coming home button and made up the wiring the same as in the diagram. I've got Zenon's and with the coming and leaving home functions activated in Vagcom, the features work fine when the coming home button on the light switch is pressed on. I can't see the difference between having the button and not so in theory, the function should work. But there again, I haven't managed to get the auto lights working so I'm no expert!
    I would like to do the same thing as I've got a new light switch with CH/LH button but I can't find the wiring diagram. The link doesn't work anymore.
    Can anyone help?
    The car is a 2006 A3 Sportback.
    Audi A3 8P Sportback FSI 2.0T
  14. #293
    rdfcpete's Avatar
    Apr 2008
    117
    Has anyone had the grand success of this working on a March 2010 or later car yet?
    I'm absolutely desperate for the leaving home lights (specifically).
    Pete.
  15. #294
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    I did one the other day on a newer A3 where the coming home is enabled and then on a separate tick box there is a check box to set the coming home from auto to manual... as there is no rain sensor the auto option does not work but when set to manual all you have to do is switch the car off and then flick the full beam stalk and the lights will come on when you open the drivers door and stay on as you lock and leave the car.
    unfortunately i couldnt get the leaving home to work.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
  16. #295
    rdfcpete's Avatar
    Apr 2008
    117
    YGM Ash!
    Quote Originally Posted by Ash187 View Post
    Pete.
  17. #296
    Jul 2013
    41
    Quote Originally Posted by rdfcpete View Post
    Did you ever solve this problem?
  18. #297
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    Yeah by installing auto lights
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  19. #298
    Belchie's Avatar
    Oct 2013
    Hi all. I'm new to this site and a complete newbie to forums in general! I have done this little mod this weekend and it worked perfectly. Just a little piece of wire and some coding magic and job done! I take my hat off to you for thinking this little mod up.
  20. #299
    Aug 2013
    26
    HELP!
    Quote Originally Posted by Belchie View Post
    Hi, please can you tell me which is bloody pin 12. Got half my car in pieces and can't find bloody pin 12. I'm so lame with stuff like this so thanks to you or anyone that helps. I think I have the right plug - see attached picture. Feel free to draw on the picture and reupload it to show me pin 12. :S
  21. #300
    Aug 2013
    26
    Can someone please explain in detail where pin 12 is. This forum won't allow me to upload a photo of the plug. Please help I have my dash apart waiting to find out where pin 12 is. Thanks.
  22. #301
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    the pin numbers are on the plugs, have a good look at the corners and it should have 1 on the edge on one side and 8 on the other side (i think it goes to 8)
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  23. #302
    T33_BKD's Avatar
    Browser
    Apr 2013
    London
    55
    Visit T33_BKD's Instagram Channel
    Quote Originally Posted by Garrry View Post
    You should see some small numbers on the corner of plug E. You may have to remove the housing first o see the numbers. once found just count your way in.
  24. #303
    Aug 2013
    26
    Quote Originally Posted by T44MTD View Post
    The numbers are on where it plugs into? Is that right?
    This is what I am looking at:
    16 ▪️▪️▪️▪️▪️▪️
    8 ▪️▪️▪️▪️▪️▪️
  25. #304
    rdfcpete's Avatar
    Apr 2008
    117
    Quote Originally Posted by winrya View Post
    Not working just yet!
    Important to note I'm doing only the rain sensor and light sensor retrofit, not the FULL auto light retrofit that most people would usually attack (which involves a new windscreen, new DRV mirror etc...)
    Few bits to do but once there, I'll confirm the results.
    Pete.
  26. #305
    Aug 2013
    26
    16 ▪️▪️▪️▪️▪️▪️
    8 ▪️▪️▪️▪️▪️▪️
    Thanks.
  27. #306
    DeeGee68's Avatar
    Aug 2013
    Surrey
    25
    Had mine turned on by ASH187 when he came to do some work on my car.... I am now smiling from ear to ear!
  28. #307
    Jan 2011
    Bristol, United Kingdom, United Kingdom
    333
    So count backward from position 16 until you reach 12.
    Now: Audi A4 B8 2.0 TDi SE - Silver, Bluetooth, Parking Sensors, Auto Lights/Wipers, Auto Dimming Mirror, Hill Hold Assist.
    Before: Audi A3 8P2, 1.9TDi Special Edition, Silver,
    Armrest, MY09 Rear Lights, R32 MK5 Alloy Wheels 18" Gloss Black, Gloss Black Sline Grill, Windows Tinted, Carbon Wrapped Trim, Wind Deflectors, Alarm Beep, LED Interior and Number Plate Lights, Cupra R Splitter, S-Line Springs, footwell lights, S3 Pedals.
  29. #308
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    82
    I'm hoping to do this mod on my RS3.... But wondered if the coding had changed? Loaded things tonight on a friends laptop but the bytes / coding was slightly different?? Thanks Kev
    RS3 Suzuka Grey - Black optic pack
  30. #309
    Aug 2013
    26
    Lightbulb
    Really annoyed. I have just driven over an hour to my local VCDS person. He told me that it isn't showing the option to activate the CH/LH Lights. It took me AGES to add the 'simple' ground wire - only to find out my car can't activate the mod.
    Can anyone understand why? I have a 1.6 SE A3 55 Plate car.
  31. #310
    Aug 2013
    26
    Picture of the VCDS not showing the CH/LH light activation
  32. #311
    Jan 2011
    333
    It's down to your electronics module if you cannot see the option in VAG depends which line you have. A low line or high line. Not all a3s will have the same options available in vag. I had to change mine to retrofit fog lights.
    Get the code off the bottom of the module which sits where the plugs are. I got my camera and took a picture then message NHN and he can let you know where to go from there. I purchased my highline from him. I might still have my other one which should have CH/LH lights I dig it out and find a code for you to confirm you can have it cheap for like £30 plus pnp if it works for you.
  33. #312
    rdfcpete's Avatar
    Apr 2008
    117
    Now 100% have auto adaptive lights, leaving home lights (via LED's and front fogs, tail lights and number plate lights) and coming home using the same lights too. I needed a earlier sensor as it happens for my MY2010 car.
    As a result, I've now got two working sensors surplus to requirements if anyone wants them - both at a steal price given I paid £82 for the used one and even more for the brand new and boxed sensor Could be of use to someone attempting the same as me.
    GENUINE AUDI Q5 2.0 TFSI A4 A5 A6 A8 TT RS4 TTRS RAIN LIGHT SENSOR 8K0 955 559A | eBay
    GENUINE AUDI A5 2.0 TDI A4 A6 S5 RS5 RAIN LIGHT SENSOR (NEW) 8K0 955 559 C | eBay
    Pete.
  34. #313
    Apr 2014
    West London
    26
    anyone around london or near who can do this mod for me. I have a 2005 audi a3 8p 5 door, looking to get the Coming Home & Leaving Home Lighting.
