EM TuningJMB Retrofits
Page 3 of 3 FirstFirst 123
Results 81 to 101 of 101
Like Tree3Likes
Thread: My DIY Guide for Retro Fitting Foot well lights
  1. #81
    JRock247's Avatar
    Jul 2012
    Hampshire
    340
    Hi Guy's n Gal's,
    Brought a set of these from RobinA3 a couple of weeks ago and just want to thank Robin for supply a top quality product, just like OEM.
    Arrived save and sound within 2 days and installed with no probs.
    If anyone is after puddle lihgts/footwell lights, RobinA3 is YOUR MAN!
    Thanks again Robin.
    RobinA3 likes this.
  3. #82
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Thanks for the feedback :-)
  4. #83
    Oct 2012
    177
    Picking up a S3 2007 plate this weekend, If they are compatible with this car, I may be interested in a set of front footwell lights
    Any chance of them being white light?
    would be greatful if you could drop me a PM with a quote
    Will
  5. #84
    Apr 2013
    Kettering, Northamptonshire
    172
    Great write up Robin! Just noticed you have a G40 i used to have mk3 genisis! Do you know it the complete light led units from ebay will work and will be able to be coded etc?
  6. #85
    May 2013
    Manchester
    33
    Excellent write up! Don't think I've got the ability to do it though :-(
  7. #86
    Oct 2012
    21
    Looking for one of ur kits for the front footwell and puddle&warning lights in the door..can you pm me a price or email jacko2222@hotmail.com for a 07 s3 8p many thanks
  8. #87
    Oct 2012
    21
    Is it possible to get lighting under the Ac unit? Has anyone refitted the red light at the front inside door handles? My old a3 8l had a dimmer switch for the light pack..is this available for a 8P2
  9. #88
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Door handle LEDs can be retro fitted as a part of puddle/warning light package but you will need to buy new door handles with the LEDs already fitted, door handles are £40 each.
    Interior Door Handle LED Lighting Kit
  10. #89
    Jul 2013
    14
    Would anyone know the part number for the pin for the white connector ? and or the name/type and manufacturer of the connector ?
  11. #90
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Which white connector?
  12. #91
    Aug 2013
    Hi Robin
    Are you still making the footwell lights? i would be interested in purchasing a set. Could you send me prices?
    Hats off for the write up :-)
  13. #92
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,110
    Hi Robin
    I am also interested in this kit
    Phil
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
  14. #93
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    For enquires about this kit and door warning / puddle kits please send me a pm.
  15. #94
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,291
    Hi Robin...
    i'm just looking for a bit of info on these and not an order....
    Do you know when activating the footwell lights on the 08 pre-facelife 8p2 s3... Do you know if it gives you the menu on the display like the 58 8p3.... The reason why im asking... I put in all the cabling and even wired through a custom oem switch for the ch/lh light feature only to find out on the s3 that it was just a simple case of coding and they appeared on the menu....
    if it didnt i'd just set the brightness high and also included a hidden resistor just so I have constant access to brightness levels without having to go through vcds all the time...? Thanks
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
  16. #95
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    Hi Guys. I have just received a second hand kit from a member on the forum and I cannot get it to work. My car is a 2009 s3 8P facelift (has the DRLs.) I have followed Robins guide to a T, making sure to plug the positive feed into the correct space on the cluster, and I have made a good earth. I have also enabled the footwell lights in VCDS. The lights will simply not come on though. The bulbs are LEDs, would that make any difference? Thanks guys.
  17. #96
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    This is doing my head in, making no sense at all. Even tried running a piece of wire directly from the terminal that the number 7 wire would be touching, but no dice. Do ALL the lights need to be plugged in and working for ANY of them to work? I tried touching the end of the number 7 terminal with a face testing screwdriver, and it lit up! But yet when I plug the connector back in, I get nothing.
    Any help appreciated.
  18. #97
    pns2007's Avatar
    Nov 2008
    627
    Have you checked the polarity on the led's? Some led's work whichever terminal the +ve is attached to, some don't. (Some change to red).
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
  19. #98
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    I have tested the LEDs outside the car using a spare battery, and there is only one way the units can connect when in the car. They also came plugged in from the previous owner so I dont think its a polarity issue. Thanks for replying though
  20. #99
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Are the LEDs error free versions? Pre 11MY cars don't support standard oem led lights - you will need error free led bulbs.
  21. #100
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    Quote Originally Posted by RobinA3 View Post
    To be honest I don't know. Its one of your looms, but I do not know about the LEDs. I tested them all outside the car last night, and only one of them worked! So I took them apart and to say they are a mess inside is an understatement. Total balls of a job they are, not sure where the previous owner got them. So tonight I am going to try plugging in a standard light with standard bulb to see if that's the issue.
    If I only plug a bulb into the drivers side front connector, would it still light up, even if the other 3 connectors are not plugged in to anything?
  22. #101
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    S3 trev did you manage to get your lights working?
Tags for this Thread
