Hey!
Micky_Lee
NULL
hey, i'm new! the names Michael, i'm from Newcastle-upon-tyne! i have a A3 8p, 1.9 tdi on a 54 plate. was wondering if anyone can help... when i'm driving along the dashboard just shuts off :wacko: all lights go out, needles drop, handbrake light goes on and radio says 'safe' then few seconds later it comes back, time reset, and fuel gauge goes where ever it feels! and once came up with abs fault then went out. before the dash started going off it would be battery light coming on then go out but battery was fine and alternator was charging. now the dash just goes out! seems to be worse when its cold outside or raining but no signs of water in footwells!
any help would be much appreciated!
welcome to the forum buddy , wow that sounds like something has gone west lol hope you get it sorted , have you taken it to a garage to see if they know what it could be ?
Hi, welcome to ASN.
thanks for the welcomes! nope i haven't taken it to a garage, i think only place it could go will be Audi or a VAG specialist. i'm a mechanic for a french dealership :ermm: lol and other mechanics i know working for different places have not seen anything like it! nothing is ever simple for me! haha
welcome i wonder if theres a fauly code have you had it scanned
nope there is no fault codes, its starting to annoy me now! lol
hmmmmmmmm auto elec is the only option any aftermarket elec bits? amps/ hids ect ?
nope no aftermarket electrics, think just some stupid phone thing so i'm going to take that out. think it might be an Audi job :crying:. going to take the dash out tomorrow to see if there is anything out of the ordinary back there! thanks for the advice!
Welcome to ASN Michael. That don't sound too good. Firstly try removing instrument cluster and checking that the wiring connectors are connected properly including the individual pins in the blocks. To remove the cluster is easy, just 2 screws at bottom of cluster above steering column. You will need to remove the cover at bottom of cluster to access the screws.
Hi Michael, welcome to the forum, not long here myself and have had loads of help.
Anyhoo a mate of mine had a similar issue with her "Bruno" a Black Edition 170 Quattro A3. I've tweeted her to find what the outcome was and will let you know in due course.
I had the cluster out today, nothing looks out of place, all the wires/plugs etc look fine no signs of burning or rubbing anywhere, i have managed to get in contact with a sales man from my local Audi dealer so i've wrote down what has been happening and hes going to pass it on to one of the technicians there. Thanks Helifella for that!
This has to be one of the most helpful forums i have been on cheers guys!
Unfortunately they've not come up with a fix. My mate just tells him off when he (Bruno the B.E.) does it.
Maybe if you get a fix you could pass it by me to let my mate know?
Sounds like your alternator man. I remember my old Jetta had those same symptoms when its alternator went bad. The battery is not getting enough power to run the electronics, so that is why they are going out. When alternators go bad they can even give the battery a negative charge which is very bad for the electronics in a car. I would replace it ASAP.
in fact i am sue quick fit do the test with the battery for free.
cheers for that. I'll do a batter check on it tomorrow and check the charge rate in the morning when it normally takes a hissy fit and i'll let you know the out come!
i know its a bit late but i thought i'll tell you guys what the problem was with the dash, it was the micro processor had shut down, a company called BBA Reman repaired it for me at a cost of £160, that was with them collecting it from me and delivering back to me within a week.
598
39
2K
11
433
30
imported_S_Line
I
