Results 1 to 9 of 9
    Apr 2010
    2.0 FSI EGR Valve
    I need to replace the EGR Valve on my 53 plate A3, I was hoping that somone could help me locate one or tell me the best place to buy..
    Audi want £230+VAT
    GSF want £166inc VAT
    Does anyone have any other alternatives? the plastic cogs have sheared off which is why im replacing
    warren_S3's Avatar
    Oct 2007
    6,122
    Quote Originally Posted by sohail579 View Post
    Audi want £230+VAT
    Taken from another site:
    I fixed this by the way. The EGR valve houses crappy PLASTIC gears driven by a stepper motor with a METAL gear! The plastic gear had lost a couple of teeth so was not being driven anymore. As the maximum angle the gear moved was only 90 degrees, I just removed the gear and rotated it so that the sheared teeth are out of the range of movement. Reset the fault code and all is good! This can all be done while the EGR valve is still in situ, just open the top cover to reveal the gears.
    Is it possible for you to do the same and buy youself some time?
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    Apr 2010
    Quote Originally Posted by warren_cox View Post
    im afraid its not possible for me as when i take out the big gear on top the one underneath is the one with the problem and that will only stay fixed in that position and more than half are broken off it looks like its been trying to keep catching on something and over time its now totally worn
    Khufu's Avatar
    West coast of Scotland
    5,693
    Mine sheared off the plastic teeth too.
    All I see is:
    NEW OE EGR Valve Audi A3 VW Golf Passat Seat 06F131503B | eBay
    At the time, I got mine from Euro Car Parts for £169 a few years back.
    Apr 2010
    have managed to source one for £50 its used but a heck of a lot cheaper!
    Apr 2010
    is there anything i should know when changing my EGR Valve? i know about the hard to get to bolt but how about seals? is there any seals i should be changing?
    Apr 2010
    anyone? do i need to replace any seals?
    Khufu's Avatar
    5,693
    I fitted a new one so im not sure but i cant see them needing replaced unless they are obviously split or worn. Apart from the teeth, mine looked like new, not like some of the diesel ones you see on the forum.
    Apr 2010
    Quote Originally Posted by Khufu View Post
    thanks will check it out when i install then
