Volks AutosMonster Motorsport
Results 1 to 20 of 20
    HP
    HP's Avatar
    May 2009
    Bournemouth
    52
    time for new discs and pads
    hey, i need to get new discs and pads. i dont want to spend a lot of money, ive been looking at Euro Car Parts and they have ATE or Eicher discs for cheap. Should i go for OE or upgrade to something better (but remember not too expensive!). what are some good pads to go on those discs? or recommend a better setup! thanks.
    thinking of Black Diamond discs and pads now - 308 from euro performance i cant afford any more than this..
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ds2500 pads and standard fit discs best combo for your budget, drilled/groved or any other type of disc will make little difference to stopping power, but the pads will so id go std discs and ds2500 pads should be cheaper then the blackdiamond stuff and work better
    HP
    HP's Avatar
    May 2009
    Bournemouth
    52
    are ds2500 track pads? on europerformance.co.uk it says Track. the street ones they have are "Ferodo DS Performance Pads (Rear) 'Street'" are they similar?
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ds2500 pads are effectivly track pads but there also very good road pads there not noisey at all and work increadibly well, i have them with my brembos and its amazing
    the ds pads wont be quite as good be ok for the rear but up front you want ds2500's, i got mine from badger5 about as cheap as anyone
    HP
    HP's Avatar
    May 2009
    Bournemouth
    52
    do you know if the ds2500's will fit on my standard calipers?
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    should do call bill at badger5 he will conferm
    Dennis Moeller's Avatar
    Jan 2007
    NorWay
    442
    EBC make OE brakes too and they are very cheap. Same steel and quality as EBC's own Turbo Groove discs my supplier told me. Even made at the same factory. Off course they're without the Zink coating which will give nothing tbh and they're also without the grooves which will add nothing but noise.
    I have those budget EBC with EBC Red Stuff (100% ceramic, no steel - no dust)...imo a very adequate combination on the S3. They will stop your car fast. DS Ferrodo is alledgedly the best out there. I haven't tried them myself but a mate has them on his RS2. Made quite a difference to his car's braking capacity. They're expensive though and have a steel/ceramic mix, therefore the bite hard. And they will wear your disc faster.
    My two pence
    My old car.. Still miss the lil rocket :-)
    Remapped Stage II - Forge FMIC - Dahlb�ck Intake - K&N - DieselGeek ShortShift - Phenolic - Powerflex Dogbone - Rial Daytona Race 8.5x18" ET30 - Forge Tiebars - Bilstein B8 - H&R 25mm - R32 rear ARB - H&R 20mm Spacers - EBC Discs - Red Stuff pads
    ______________________________________________
    NO ONE EVER REALLY DIED
    HP
    HP's Avatar
    May 2009
    Bournemouth
    52
    i think the Ferrodo's are gonna be too expensive. also i should have mentioned my car is only a 1.6 - perhaps not worth it. EBC don't seem to do Red Stuff for 1.6, but they do do Green Stuff. might end up going with these unless anyone can recommend another pad?
    Jun 2009
    77
    Just get OE quality for a 1.6. They are nice quiet brakes and will last, id use ATE, never had a problem with them as we fit them all the time on bmw/vag cars.
    1999 S3 Quattro. Stolen by my cousin in exchange for pennies !!
    Honda Civic Type R Premier
    Jan 2007
    NorWay
    442
    Go for OE with better pads. Even though you only have a 1.6 you'll need as good brakes as you can afford. Stopping 3-4 meters shorter maybe means that you can avoid hitting something or someone - VITAL even with moderate power :-)
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I have EBC Greenstuff pads. There was some concern from S owners over them but on my A3 they're brilliant...cant fault them and they're a huge improvement over the standard ones.
    My discs were from GSF, they're just cross drilled ones by a company called Zimmerman. Again...cant fault them....plus they were under 50 each.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    HP
    HP's Avatar
    May 2009
    Bournemouth
    52
    thanks for the help guys, ive ordered Greenstuff pads and OE ATE discs all round. spent about 170 for everything.
    Aug 2004
    526
    Bit late i know and haven't got personal experience, but mostly read bad things about EBC green/redstuff pads.
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    HP I emailed a seller on ebay about mintex xtreme pads for my car, if they would fit. He replied back asking do I have ATE calipers. What are ATE and how would I know if a S3 has them
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    ATE are the standard S3 brakes (calipers, pads and discs - as far as I'm aware), it's just the name of the manufacturer.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    ohh I see. Anyone had any experience of mintex xtreme pads.
    For sale
    PM for info.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by Dennis Moeller View Post
    My two pence
    EBC REDs & no dust my arse... sorry fella
    I have Reds on my 8pot RS6 Calipers on my S6 and they dust the same as any pad.
    they will tear up disks faster when pushed, more so the yellows, and are not in the same league of performance and longevety as DS2500/DS3000 series pads.
    DS2500's for S3's are readily available and stocked by me for Leon Cupra's etc. same fitment.
    {no wear sensors is their only downside}
    great pads - luv em myself on my racer
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by A3Tom View Post
    T
    I can only guess you dont work your pads hard if greens suffice.
    when used in anger they will fade and wear out like a mofo.
    they're not for heavier cars but light 106's and the like
    www.badger5.biz
    bill@badger5.co.uk
    Jan 2007
    NorWay
    442
    No problem Badger...Just meant to say that they dust less than OE pads. At least that's my experience. Red stuff will tear up the discs faster than OE pads, sure, but not nearly as fast as DS2500 etc...
    Anyways, never doubted that Ferrodo have good pads...!
    WildBruce's Avatar
    Third Gear
    Oct 2008
    London
    197
    Badger, how much for the 2500? and can I chuck them on with my standard disks?
    Wear sensor just came up, so I guess I need to replace some pads, but it looks like I may not get this reminder if I upgrade to these pads. If I want to keep this feature, and still have good stopping power [225 S3] what would you recommend?
    Also, can you deliver by Monday if I order tomorrow?
