Results 1 to 13 of 13
    Jun 2004
    South Wales
    47
    ESP light: HELP!
    Got a 2000 'W' S3, managed to get hold of the newer facelift model steering wheel. Since changing it over have had the dashboard ESP light on. Has anyone here changed to a later wheel? Did you encounter this problem? Or have I made a silly mistake? Is this wheel is compatible with my model car?
    Please help as light is starting to get on my nerves! I don't want to take it to the Stealer to sort!
    Thanks.
    imported_bayliss
    Re: ESP light: HELP!
    could this be due to the airbag needing reset???
    Jun 2004
    South Wales
    47
    Airbag light was reset using vagcom, but ESP fault would not clear.
    imported_bayliss
    got me then sorry fella!
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    Whats the fault code?
    Jun 2004
    South Wales
    47
    Don't know what code is. I was told that the vagcom detected the fault, but no code was given???? I don't know if that makes any sense to you. I'm not that up on this kit.
    Does anyone know if the later wheel is def compatible with earlier cars??
    imported_andy999r
    My esp light came on with my n75 valve problem. Does it go off when you switch off and on, ie reset?
    Oct 2003
    South Wales
    2,942
    Chris,
    You said that your car seemed down on power also, I think the n75 would cause this (Correct me if I am wrong guys).
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    Isn't there an ESP sensor in the wheel that detects it's position?? If it were bad or not wired in correctly, an ESP fault would result [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    [ QUOTE ]
    [/ QUOTE ]
    I thought that the sensor in the Swheel was set lower down, nearer the indicator stalks (2 plastic coils that pass over each other to detect position - its these that caused my "clicking" problem on steering).
    Possible though to have disconnected part of this ESP sensor setup when changing Swheel, might be the reason for givin a fault code on trhe VAGCOM?!? i.e. nothing to detect?!? [img]/ubbthreads/images/graemlins/confused.gif[/img]
    imported_gjrquattro
    If you have upset the steering angle sensor when fitting the wheel it needs to be re-programed. Can only be done at the dealer. [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Jun 2004
    South Wales
    47
    Dealer it is then! Whats this about the n75??? or rather what is the n75, and how do I reset this? as car feels slower, or held back (if this makes sense)
    Perhaps I have 2 faults.....great!!!
    Jun 2004
    South Wales
    47
    Everything fine now! Steering angle sensor was broken/Damaged when I swapped the wheel?? Can't think how I done this,as I was very careful, but stealer fitted new one and everything is great again! [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Warning: be careful with this as replacement part is 160 + the tw#t!(VAT)
    How nice it was of the Dealer to have one on the shelf!
    Thanks for help guys!
