EM TuningAH Fabrications
Results 1 to 13 of 13
    bansheeboyo's Avatar
    Dec 2008
    aberdeenshire
    203
    best dump valve for a 1999 audi a3 quattro
    Hi guys would like your opinion on what the best dump valve is for a standard 1999 audi a3 1.8t quattro,i have been looking on the net but can only seem to see baiiley dump valves are these any good i was looking for hks but unsure if they will fit,new to the whole car thing.
    thanking you in advance
    scott.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Don't fit a dump valve at all...it'll only cause your engine Management problems as it gets confused as to where the metered air has gone...leading to longer lag between coming off the throttle and getting back in it, slightly decreased performance and sounds utterly Chav (in my view).
    What you need is a Divertor Valve, so it keeps the dumped air in the system.
    Forge make some good Divertor Valves.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    A3ster's Avatar
    Oct 2008
    87
    Hi, most people go for one of these
    http://www.forgemotorsport.co.uk/con...DV&inc=product
    But you can get the OEM from Vagparts for a fraction of the price. The forge ones are better for mapped 1.8Ts but no reason not to have one if your not mapped, apart from the price.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As said, you need to use a recirculating diverter valve and nt an atmospheric dump valve. Most 1.8T owners go for these...
    http://www.dpmperformance.co.uk/forg...996-p-887.html
    Damian @ DPM
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Dark Knight
    Jul 2008
    936
    Talking dont !
    Dont get a dump valve that will give u no advantage and you will just sound like a fool ...
    Quote Originally Posted by bansheeboyo View Post
    scott.
    Current Audi A3 2.0 TDI New shape
    Audi S3 -MAD / Tax Beater /Forge 007/Stage 2 Vagcheck /
    Mk2 G60 Stage 4 Jabbasport
    Corrado G60 Stage 4 Jabbasport / Porsche Rims / bhp 265/ decat
    Dec 2008
    Quote Originally Posted by DPM View Post
    Damian @ DPM
    As said by Damian and others you dont want a 'Dump Valve' as such, the Vag 1.8 turbo engine uses a recirculating air system, this means that the air that would be dumped has allready been measured and accounted for by the ecu. You need to fit a recirculating diverter valve, this way the engine gets its air back just like stock and doesnt run rich and splutter on every gear change.
    I can only speak for the Forge 007 that has allready been mentioned as i have one in my s3 and its solid as a rock. If you want the dump valve noise then fit a cone filter at the same time and you will be able to hear plenty of wosh on every gear shift under boost.
    Damian - I will be coming yourway in the new year to get a DV cold side relocation kit for my S3, do you know if you still get the above mentioned wosh on gear changes or does that tend to go away as your dumping less air between gears?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    With a induction kit you will get a nice noise from the 007P but you do get more from the Splitter valve, but we still prefer the 007P.
    Damian @ DPM
    DPM Performance
    T: 01207 561606
    Yaz
    Yaz's Avatar
    Oct 2008
    Essex
    225
    Damian @ DPM
    Are these splitter valves (Forge) ok though? I want one of these, but not if its going to cause me problems.
    1994 Audi 100 Avant 2.5TDI
    1987 VW Scirocco Scala
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    They don't cause problems and do give you more noise then what the 007P's do, you'll be fine with it and it's a great valve, just personal choice that we prefer the 007P's.
    Damian @ DPM
    DPM Performance
    T: 01207 561606
    Yaz
    Yaz's Avatar
    Oct 2008
    Essex
    225
    Damian @ DPM
    Ok cool, thanks for confirming that. I get some sort of satisfaction from the noise of my gases dumping!
    I want to buy one of these asap, just gotta choose somewhere...
    Oct 2011
    15
    007p reversed is loudest whoosh sound possible iv found with 1.8t. Does get boring though LOL
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Quote Originally Posted by @unger View Post
    ...although this is not the way its supposed to be fitted and can allow the DV to be forced open under high boost....
    <tuffty/>
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,160
    Reversed 007P sounds like a load of poo if you ask me. More of a high pitched chirp then a whoosh noise.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
