Results 1 to 33 of 33
Like Tree3Likes
  • 1 Post By ScottD3
  • 1 Post By COSTA_P
  • 1 Post By COSTA_P
Thread: Double din dash
    Oct 2012
    42
    Double din dash
    Fitting an RNS-d and came across my climate control not fitting due to the space/ angle on the centre console. So I need a different climate control or is there a slight variation on the centre console. My car is a facelift model and my RNS-d also came with the double din caged and a centre console. My car was single din before hand.
    Any any advise or guidance much appreciated. Thanks. Phil.
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    387
    The double DIN and single DIN climate control units are different bud.
    Oct 2012
    42
    Damn. Ok mate thanks for the quick reply. Do you know what the double one looks like?
    Nov 2011
    Horsham
    387
    Pretty similar mate just a slightly different size. Scout eBay and you should be able to pick one up.
    2000 Plate Audi S3 1.8T Santorin Blue - 261.0BHP - 255.1LB/FT on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Most people doing this conversion trim the sides of the climate control unit... the cage is differnt too on double din... I went double din to single din but swapped out with a guy wanting to go double so was easier... double uses a metal cage... have to strip all the centre console to get to swap it correctly....
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    ..aslo... if you had taken the time to read the FQ thread in the stickies you would have found this...
    Double Din Conversion / RNS-D Retro Fit
    ...which I think will cover the other thread you started too...
    Fitting RNS-e
    Try and stick to one thread though please keeping context of what you are doing as this type of conversion is of general interest and is useful for others if its not spread around several threads...
    Ta
    <tuffty/>
    Oct 2012
    42
    <tuffty/>
    ah really. Ill give this a go at work tomorrow and take some photo. The cage is no issue as i got that with the nav unit. Ill upload some pics of current progress. Im not sure if my car is CANbus or tbh the actual meaning behind that term, as im getting a message in german when i put in my security code that it can not connect. I think this means it cant connect to the car and maybe needs a vcds scan to accept the unit.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    8L module comms is k-line but stereo uses canbus comms to the dash and for controlling power IIRC...
    <tuffty/>
    Oct 2012
    42
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Thats just the radio code you need? might to have the unit re-coded if you don't have it already...
    <tuffty/>
    Oct 2012
    42
    the code on the screen is the one thats on the bottom of the unit so im guesing it was right. recode an audi only job?
    Oct 2012
    42
    got the dash all fitted now. still no luck with the nav unit connecting. Am i missing part of a loom? as this is the only connector that i havent got, the rest is plugged in from the original.
    Oct 2012
    42
    Also my car is non Bose. If the unit came out of a Bose car would I need this scanned into mine? Still having no luck with it connecting. Not sure what's up!? Anyone with any ideas?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    You're missing the GPS aerial, Speed sensor and if its from bose you need to change the coding to a none bose car.
    Aerial
    SMB GPS ANTENNA FOR AUDI NAVI PLUS BNS RNS E D | eBay
    and you need to get a 26 pin locking plug for the 2nd speed sensor.
    Does your car have a diversity aerial?
    If not, what is that plug that you got plugged in to the Diversity aerial plug?
    Do you have the stereo code?
    PM S8Criag, he should be able to supply you with the correct plug and cable or contact Audi, they can get it.
    I assume you don't have a TMC box to go with it?
    What stereo did you have in there before?
    Do you or did you have a hands free kit or CD change?
    I'm only asking cause the plugs for CD changer, Telephone and Bose is populated. I'm not sure what they was doing in the last stereo, so little concerned that they might cause issues if sending something in to the RNS or out of it that's not meant to go along them lines.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Oct 2012
    42
    is the gps aerial not in the top right hand corner as i do have one. The stereo code i do have its the one in the photo and comes up with that message once its entered.
    Not sure about my car having a diversity aerial, how do I tell what it is?
    Also is the 26 pin locking plug for my missing connecter? does this go into the loom somewhere?
    No TMC box came with the unit.
    No cd changer although it could have been taken out at an earlier stage in its life. I do have an ipod/ iphone interface that plugs into that now though, which im guessing has taken them up as my phone when connected can come through the speakers.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Quote Originally Posted by COSTA_P View Post
    Cool. Yeah that's where it should do.
    Did you connect the safe cable?
    there is a extra constant live cable on the black plug that needs to be in there
    My understanding is that it selects the aerial with the better signal. Its the plug on the bottom to the right of the radio aerial plug. You have a brown plug in there.
    Yup, its the missing plug. Its part of the speed sensor, it has other options like canbus, reversing signal and some other bits but they are not needed really.
    I would not worry then. No need to go down the canbus route.
    That's cool.
    Oct 2012
    42
    Ah right yeh got that bit of the airel but need like an adapter or something for it to fit into the RNS properly.
    Where could I get the 26pin plug from? Does that need wiring into the car loom somewhere?
    Don't think I've got the safe wire in either. As it doesn't power on or off with ignition you have to press the button.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    PM S8Craig or pop to Audi.
    You only need to wire in one cable and its the speed cable from the Gala signal.
    You need the Safe cable.
    The stereo should still turn on with no safe cable.
    look on top of the unit, there is a wiring diagram.
    Make sure that matches what ever unit you took out.
    dusty's Avatar
    Nov 2010
    nw england
    144
    Hi Costa, I'm wanting to fit an rnsd to my s3 I've sourced most of the parts, there is a company called kufatec that can supply you with a wiring loom, as said above you will also need a tmc unit to display sat nav directions onto your d.i.s. I'm looking for someone to do the conversion for me as I'm useless with wiring and electrics
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Audi/ VW adapter head unit MFD RNS-D (Navi+)-33361 Add £7.50 for postage.
    If you're not confident in wiring, then its worth getting.
    dusty likes this.
    Oct 2012
    42
    I'm not bad at wiring ill give the loom a go and see how I get on. If it all goes Pete tongue ill have to find a proper fitter. Live and learn. Thanks for that link ScottB5.
    where can I get and what is the TMC?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    TMC is a traffic management control unit (or something like that).
    It does 2 jobs.
    1st is to record, log, look out for traffic jams that's transmitted over the radio waves and then divert your journey around the jams.
    2nd is as a canbus gateway. It converts the canbus signal from the radio in to a signal that the rest of the car can understand and convert the car signal back to the radio.
    The main thing that most people use it for is to get the satnav directions up on the dash.
    TMCs range from £60 to about £100 on ebay.
    You'll need a new loom which is about £30 on ebay.
    Oct 2012
    42
    Awesome info again cheers mate ill get on the hunt for it.
    Oct 2012
    42
    ScottD3 likes this.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Oct 2012
    42
    sweet ill get it ordered! nice one again ScottB5, very helpful.
    ScottD3 likes this.
  28. #27
    Oct 2012
    42
    Right finally got it up and running. Wiring took its time to come.
    Some issues
    1: tmc tuner. Is there a wiring diagram anywhere?
    2: my satnav disc is a copied one and scratched so isn't reading. Can I get another?
    3: it doesn't power on and off with ignition have to use the button on it. Can I just run the power to ign?
    Think thats it it off the top of my head.
  29. #28
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Some issues
    1) yes but the link where I got my info has been shut down. But its basic. Two power, two can bus to stereo and two can bus to cluster.
    I will look tomorrow for you.
    2) yes. I know a man. I will get his details for you.
    3) if you then it on with engine running, take they key out does the stereo turn off?
    If it does can you start the car again, does it turn on?
  30. #29
    Oct 2012
    42
    Sweet cheers mate. No it stays on have to manualy turn it off.
  31. #30
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    you might have the constant and ignition lives round the wrong way.
    Also did you the standard car wiring or make you own?
  32. #31
    Oct 2012
    42
    Used standard wiring just bought the looms off eBay. From the above recommended brand. The 26pin for the speed sensor that want occupied in the previous photos still hasn't got anything in it. I'm guessing that's for tmc and gala speed?
  33. #32
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    You bought the TMC loom or the other one with for the speed sensor?
    You need the 26 pin one for can bus to the tmc and speed sensor for the satnav.
    I'm not sure why its nots turning on and off with the ignition if you used all the standard wiring and there is no power missing. Should be 3 positive cables in total.
    2 constant and 1 ignition.
  34. #33
    Oct 2012
    42
    TMC TUNER CABLE FOR VW MFD and AUDI NAVI PLUS DX 0131 | eBay
    I bought that to wire in my tmc tuner, the CAN H and CAN L I'm guessing go on to pin 13 and 26 on the rnsd unit, but i also got this
    Audi VW Adapter Radio Navigation MFD RNS-D Navi+ Golf 4 Passat A3 A4 A6 33361 | eBay
    which has the 26 pin for the speed sensor but its sealed? so i can't see a way of getting the CAN H and CAN L in there that will connect to the rnsd unit, the other H and L will be wired into the clocks, power and ground pretty obvious.
    ill take some photos of how my wiring stands at the moment to give you a better idea ScottB5.
    Cheers for your help.
  1. 8l facelift double din dash
    By Den13 in forum For Sale/Wanted - Audi Cars
    Last Post: 31st December 2012, 19:32
  2. Facelift dash single to double DIN climate control question
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2010, 18:58
  3. double din/satnav dash pics required
    By Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2006, 18:56
  4. 7" Screen in S3 double din slot
    By imported_MattT in forum In-Car Entertainment
    Last Post: 5th October 2004, 09:31
  5. Help with fitting SYMPHONY double-din head unit
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 21:29
