Quick TIP Fitting Question
WorkInProgress
Scotland
Fitting a Forge TIP to my AGU, Jubilee clip, Mikalor or JCS Hi Torque to fit it to turbo?
Jubilee or JCS... JCS are better quality but you certainly don't need t-bolt clamps :)
<tuffty/>
T bolt clamp onto the turbo would be a pain to fit, as its larger (width wise typically) and as there is very little room down there already, this would probably have clearance issues with the T bolt clamp sitting against the turbo and getting enough TIP onto the turbo inlet to grip (if that makes sense)
Mikalor or similar quality is fine.
