EM TuningMonster Motorsport
Results 1 to 33 of 33
Like Tree7Likes
  • 1 Post By Jay A3
  • 1 Post By @udi A3
  • 2 Post By Jay A3
  • 2 Post By jojo
  • 1 Post By jojo
Thread: Remote Central locking
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Looking for some advice on upgrading my key. I currently have the single key with no remote. I would like to have the flip style with the 2 button remote.
    I Read the link below (thanks Tom)
    http://www.vwaudiforum.co.uk/forum/s...king-FAQ/page3
    This helped explain what central locking unit I had and what unit I need.
    "8L0 862 257 early model remote c/l pump, has limited functions e.g wont operate door pin led's or flash indicators on unlock
    8L0 862 257 'A' early model non remote
    8L0 862 257 'H' 98-99 non remote pump
    8L0 862 257 'G' 98-99 remote c/l pump uses 2 button remote fob
    8L0 862 257 'P' 99+ facelift model pump, all facelift have remote c/l and so behaves oddly if you use the key to open door (drivers door only will unlock untill you turn ign. on) they also use a different siren (batt back up type) so arent compatable with earlier cars"
    I had a look and found that my CLM was 8L0 862 257 H which is the non remote.
    According to the above I need the 8L0 862 257 G module.
    Now i Managed to find one and tried to connect it today. Located in the rear quarter I disconnected the Two air line pipes and 3 electrical plugs
    Thought I'd try and swap the units over to see what would happen. The module works! Unfortunately that was it. I could hear the pump going, pin locks going up and down, alarm goes mental and the front windows drop down.
    Keys and remotes had no effect. Only way to stop the alarm was to disconnect the "G" module.
    I read that I may need to soft code this new module in using vagcom. (Complete amateur at vcds)
    I didn't know if there was a correct procedure to change this over without the alarm going constantly?? Hopefully once this is installed I can look into remote keys!
    <Jay A3 build thread>
    241bhp K03s - R Tech
    May 2012
    RETFORD, NOTTS
    1,716
    Check original units coding in the correct module in vcds, then click coding. write the number down.
    Fit new unit, check coding is the same, if not check and erase fault codes, then in coding enter the same as original units coding, or use the pop up info to work out a new code.
    Once coded Id suggest closing and locking car for a minute then open and check operation of central locking. if it functions normally you could probably have a new remote key programmed to work. If the alarm plays up still check error codes, it may continue to play up untill a new remote is coded. Unfortuately i dont know all the answers here, but im keen to see this solution working and possibly offer a retrofit to others :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Seems straight forward. Once I get vag com up and running I will log the current unit details. Then try and swap the units over in a more appropriate area (don't fancy upsetting all my neighbours with the constant alarm going off)
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Not much success today. Connected vagcom to the car today and got the soft code from my current module.
    After a few discussions with Tom the plan was to copy the current central locking code onto the new module (vcds/select module/35-central locking)
    Tried the new "G" module today. Plugged it all in and the motor went mental. It kept locking and unlocking, the motor was working double time. Plugged vcds in and kept getting a no Response / connection from module. Plugged the original unit back in and it read in vcds straight away (confirms that the vagcom is working) this now leaves either the module is not compatible or the module is faulty. Now on the hunt for another "G" module to test!
    May 2012
    RETFORD, NOTTS
    1,716
    Sorry jay, didnt have time in the end to come over, was still sat in that ibiza till gone 9 ripping out the failed clifford alarm! Simple dash swap we thought, nothing ever is simple when buying problem cars !!
    Feel free to cal round thursday/friday though :D
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    No worries mate.
    Didn't have much joy yesterday so doubt it would have been a positive visit anyway. Will give you a bell when I'm local. On the meantime the hunt continues for a new module
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Update
    Sourced another "G" module from the local breakers. £20 including 2 keys from the car it came off... Not a bad price.
    Swapped the modules over and was ready to soft code it in using vagcom. RESULT! I didn't need to soft code anything. The new module worked straight away with my current aftermarket remote. Doors locked and unlocked as it did before. Only difference is this new module should support and use OE remotes.
    Ordered some new cr1620 batteries in hope that the OE remotes will work off the bat. If not then a little re-programming is required.
    Hopefully it does meaning I can have OE flip keys and also get rid of this silly aftermarket remote / unit.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Ok... So new unit has been working fine but not with the oem remotes. I scanned it with vagcom at the garage and tried to manually re-program the remotes but no joy. Looking at the 35 - central lock I could only see channels 1-4. Anything above was "error" came to the conclusion the aftermarket remote unit installed maybe interfering with the OE system so I disconnected it. Still no joy same thing happened.
    Met Tom up (@udi a3) and he had a go. Initially came up with the same problem as me. Remotes wouldn't program in. Ended up taking my unit out and swapping it into his a3. Worked straight away and he programmed the remote in there. Dropped the module back into mine and nothing... Vcds plugged back in and watching block 4 there was a glimmer of hope. Only happened once but when Tom pressed the remote and the block changed from 0 to 1 meaning the module recognised the action.
    Didn't happen again but I remembered that my car had been waterlogged in that area a while back due to a leak from the rear wiper. The plugs are a little corroded (tried to clean it with contact cleaner) it worked but was intermittent. Tom is 95% sure it's the plugs so this weekend I will be replacing the plugs.
    ScottD3 likes this.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    Got any other electronics down there that could have been flooded?
    Worth checking them as well.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    I will have a look, but from memory all that is located down there is the module with 3 plugs and 2 vac lines everything else is situated above.
    May 2012
    RETFORD, NOTTS
    1,716
    I pinched a spare set of plugs from the scrappy if you need them, was thinking about making a bench loom to reprogram modules without pulling my car apat in the future!!
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Thanks Tom, I should have a set at the garage already. A work bench would be handy, the yellow vac pipe of yours looks fragile at the moment so best to avoid taking it apart each time for testing
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Saturday has been and gone!
    Found the plugs
    What the corroded plugs looked like
    Had a go at soldering and I was crap at it. Got the job done in the end, just took a while...
    The remote that tom programmed in when I last saw him works! Open and unlocks as it should. Indicators don't flash and windows do not go up and down when the button is pressed. Might need to be coded in??
    The other issued is the range of the remote. The remote only works when I stand directly behind the boot, module side.
    The conclusion - remote antenna...??
    Is there one if so where is it located? I need to compare the wiring setup of mine compared to an a3 with a remote as standard. Maybe its something as simple as connecting a wire and extended the antenna?
    I need to source wiring diagrams... Can anyone help?
    Much appreciated!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    Sounds like you need coding for the windows and the flashed.
    Time to VCDS.......again/more
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Yeh I will look into that... On the hunt for wiring diagrams
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    I'll get on the laptop later and take a look
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Cheers Scott, I'm hoping it's just tapping off another wire
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    remote locking?
    Found this on Google search as appose to search bar which I cant seem to get on with
    Danio mentions the aerial here so need to check that out first
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    This any good?
    It looks like there is one radio signal cable.
    Edit: Same as what you found.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Thanks Scott.
    When It stops raining I will have a look a the module and check plug C. (Smaller black plug) according to danio the part number I might need if aerial is required is 8L0 900 433
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    Sure on the part number?
    I can't find it.
    I type it in to ETKA and nothing is found.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Again I googled the part from the thread I posted up. The only site that seems to sell it is from Germany
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    Try 8L1971207 but its been superseded by 000 098 652 Aerial connection line and 000 098 670/000 098 705a adapter aerial wire.
    Fakra cables from Audi | Audi Forum
    May 2012
    RETFORD, NOTTS
    1,716
    This is good stuff, another member had the same issue recently when i programmed the remote on a scrapyard sourced pump, range is good on my car, but put on their car and was pants. hopefully he reads this and does the same!
    Jay A3 likes this.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Found a spare "C" plug that had come from an a3 with a remote.
    The difference I can see is the addition of the thick black wire. Which looks like the it could be the aerial
    Opened it up and I can confirm they this black wire connects to pins 1 and 7 of plug C
    I now need to find out how long the aerial is, what the route is, how long and is there anything on the other end??
    If not then maybe I can just extend the aerial if I can get the same wire..
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Success!
    @udi a3 kindly went to a scrap yard and found an a3 with this aerial. All it is, is an extension of the black coaxial cable in the pic above. It is approx 0.5m long. Connected to the existing spare plug I had to hand.
    In the car and worked straight away. I have fully tested the range but 10ft and it worked fine.
    Following that tom started on programming the new transponder chips to the keys and then the new non genuine remotes. Made it look so easy...
    The remotes feel and look good, I went for the 8P style remote
    Tom even coded in so that the windows go up and down when the button is held, and the indicators flash when locked or unlocked. All that is left is the keys being cut which again tom is arranging for me.
    Happy now the remote all works...
    Great service from @udi A3, I couldn't be happier with the result!!!
    ScottD3 and @udi A3 like this.
  28. #27
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Good work! I ordered an 8P style key for my S3 aswell, quite happy with it! Cheers Tom!
    Jay A3 and @udi A3 like this.
    You've got to have a laugh!
  29. #28
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    Quote Originally Posted by jojo View Post
    Wish I picked up a bently one now
  30. #29
    May 2012
    RETFORD, NOTTS
    1,716
    Thanks for the good feedback guys :D
  31. #30
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Quote Originally Posted by ScottB5 View Post
    Not happy with your screwdriver?
    Jay A3 likes this.
  32. #31
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,698
    Either the novelty has worn off or Scott drives too sensibly to get pulled over so he can get a reaction from the police when they see the screwdriver in the ignition
  33. #32
    May 2012
    RETFORD, NOTTS
    1,716
    That screwdrivers pretty good, but it has no remote... i think it should be a custom moulded stubby handle with an old remote board fitted...
  34. #33
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,682
    Its not very pocket friendly.
    Quote Originally Posted by Jay A3 View Post
    I tried but cops just arnt interested in me any more.
    Quote Originally Posted by @udi A3 View Post
    Send me a spare board and I'll see what I can do.
  1. REMOTE CENTRAL LOCKING
    By imported_AudiAuto in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2004, 00:21
  2. Remote central locking problem!someone please help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:43
  3. Remote Central Locking
    By imported_rosssummers in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2004, 18:58
  4. Remote central locking kit from Vagparts.com
    By cloggs in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2004, 17:58
  5. Remote central locking upgrade?
    By mareksio in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 18:06
