Evening all
looking for some advice on some data i retrieved from the car using vagcom. main symptoms i have are hard cold start, general power loss and car doesnt want to rev under acceleration past approx 5.8k rpms.
several fault codes and a logged third gear pull below
3 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
17522 - Shareware Version. To Decode all DTCs
P1114 - 35-00 - Please Register/Activate
16706 - Shareware Version. To Decode all DTCs
P0322 - 35-10 - Please Register/Activate
3 Faults Found:
P1118 - 35-00 - -
RPM | Load | Inj. On Time | Mass Flow | RPM | Temperature | Lambda | Bin. Bits | RPM | Voltage | Temp | Temp | |||||
TIME | TIME | TIME | ||||||||||||||
STAMP | /min | % | ms | g/s | STAMP | /min | °C | % | STAMP | /min | V | °C | °C | |||
0.91 | 920 | 32.3 | 5.1 | 11.67 | 0.01 | 1760 | 81 | 0 | 110111 | 0.4 | 1680 | 13.65 | 81 | 36 | ||
2.13 | 1480 | 50.4 | 5.78 | 17.97 | 1.31 | 1080 | 80 | 0 | 110111 | 1.71 | 1200 | 13.86 | 80 | 37 | ||
3.42 | 2000 | 23.3 | 2.38 | 9.92 | 2.62 | 2040 | 80 | 0 | 100101 | 3.02 | 1960 | 13.86 | 80 | 36 | ||
4.72 | 2200 | 65.4 | 5.78 | 32.39 | 3.82 | 1960 | 80 | -5.5 | 101011 | 4.32 | 2080 | 13.79 | 80 | 37 | ||
5.95 | 2800 | 82 | 7.48 | 46.44 | 5.14 | 2360 | 80 | 5.5 | 101001 | 5.54 | 2600 | 13.72 | 80 | 37 | ||
7.36 | 3640 | 97.7 | 8.16 | 71.56 | 6.45 | 3080 | 80 | 6.3 | 101001 | 6.85 | 3320 | 13.58 | 80 | 36 | ||
8.65 | 2800 | 16.5 | 0 | 6.22 | 7.76 | 3880 | 80 | 10.2 | 101001 | 8.16 | 3800 | 13.79 | 80 | 34 | ||
9.87 | 2720 | 85 | 7.48 | 47.5 | 9.05 | 2600 | 80 | -0.8 | 100001 | 9.47 | 2640 | 13.86 | 80 | 34 | ||
11.37 | 3240 | 116.5 | 11.9 | 76.64 | 10.37 | 2840 | 80 | 10.9 | 101001 | 10.88 | 3040 | 13.79 | 79 | 35 | ||
12.57 | 3880 | 160.2 | 20.4 | 127.03 | 11.77 | 3440 | 80 | 15.6 | 101000 | 12.18 | 3640 | 13.37 | 80 | 35 | ||
13.79 | 4680 | 176.7 | 25.16 | 157.39 | 12.99 | 4160 | 80 | 20.3 | 101000 | 13.39 | 4440 | 13.79 | 80 | 35 | ||
15.1 | 5440 | 178.9 | 26.52 | 182.86 | 14.19 | 4920 | 80 | 21.1 | 101000 | 14.61 | 5160 | 13.65 | 80 | 34 | ||
16.3 | 5720 | 180.5 | 27.54 | 191.22 | 15.5 | 5640 | 80 | 24.2 | 101000 | 15.9 | 5720 | 13.79 | 79 | 36 | ||
17.52 | 4320 | 14.3 | 0 | 8.69 | 16.7 | 5760 | 79 | 0 | 110000 | 17.1 | 4840 | 13.72 | 79 | 34 | ||
18.81 | 4160 | 14.3 | 0 | 11.47 | 17.92 | 4280 | 79 | 0 | 110000 | 18.32 | 4240 | 13.72 | 79 | 34 | ||
20.03 | 3200 | 15 | 0 | 9.56 | 19.21 | 3760 | 79 | 0 | 110000 | 19.63 | 3040 | 13.65 | 79 | 35 | ||
21.42 | 2920 | 15 | 0 | 8.86 | 20.52 | 3080 | 80 | 0 | 110000 | 20.92 | 3000 | 13.65 | 79 | 35 |
