Sky InsuranceChris Nott
Results 1 to 27 of 27
Like Tree4Likes
  • 1 Post By <tuffty/>
  • 1 Post By badger5
  • 1 Post By s3gazz
  • 1 Post By superkarl
Thread: Custom making map sensor pipe
    Aug 2010
    bradford
    1,252
    Was wondering guys if it would make any difference making a map sensor pipe. For some reason I've just only noticed I've got 63mm pipe from turbo to end of charge pipe then drops to 53mm back into 63mm to 76mm inter cooler and out to 63mm again up to map sensor pipe which is 53 mm and 53mm throttle body pipe and 63mm throttle body.
    Does this not mean the map sensor pipe is restricting everything as the pipe aren't hard to change but the map sensor pipe is. What u guys think
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    beachbuggy's Avatar
    Surrey
    1,745
    Buy a map flange/adaptor from forge and get it welded to a piece of alloy pipe.
    Aug 2010
    bradford
    1,252
    Was thinking somate like that dan with a 63mm aluminium pipe modded to reach the throttle body some how
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    I'm still running the standard one and that was fine at 500 bhp
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Aug 2010
    bradford
    1,252
    I just think it would flow better with a bigger pipe rather than a smaller one Ie restriction or less volume of air passing through
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    This is what you want fella... I'm getting pipework fabricated from my cooler to my 75mm Throttle Body..... With this incorporated...
    Jun 2009
    Leeds
    3,469
    I would say don't waste your money until your on a 500+ level
    I still plan to run the standard one even when or if i hit 600 bhp
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    The gains from up-sizing the pipework will vary but the basics are the tighter the hole the more boost required to obtain a target airflow... going 63mm all round will improve overall flow but only if the rest of the charge system has no restrictions too...
    You will benefit from 63mm from 300hp up... there are various theories about pipework sizing and most people that are on 500hp or more use 70mm pipework but tbh for a road car 63mm is more than enough...
    The OE MAP tube is an odd shape and a little constricted in places... while its not the end of the world if you leave it in place should you decide to change it I would suggest you plan the pipework out accordingly as I have seen some real bodge jobs in the past and it defeats the object.... I relocated my battery to get a decent path... either of the charge pipe sections I made would improve flow potential but just replacing the MAP tube is probably not worth the effort unless redoing that whole section...
    Andrew, seriously dude... at your levels you would really benefit from normalising the pipework... airspeeds alone generate heat and the volume of air and boost levels you will be running thats a lot of friction... larger pipework will drop overall airspeed and reduce heat generated by friction... will also require less boost to achieve power... worth considering in your case dude...
    <tuffty/>
    superkarl likes this.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    just because you can force an amount of air thru a smaller than ideal hole does'nt make it an efficient way of forcing it.
    size it uniformly and of correct size. /End Of
    <tuffty/> likes this.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Pressume you want something like this gazz
    Pretty sure forge sell them
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Jul 2010
    Teesside
    933
    Quote Originally Posted by StaceyS3 View Post
    The picture in my last post is from the Forge website Stacey....
    Aug 2010
    bradford
    1,252
    The hole pipe is 27 from forge so what I was going to do is get that it's 270 mm long and 63mm ID then fabricate my own bit of pipe on onto the end and make something to reach the throttle body as well. I do want a good consistent flow all the way around so this is my opposition I think.
    like we say its all about the flow same sized pipe not matter what has got to be better than it dropping to 53mm anywhere in the pipe line
    Aug 2010
    bradford
    1,252
    ye Stacey was going for that but for an extra £10 the whole pipe from forge is 27
    Jul 2010
    Teesside
    933
    This is what Tufty fabricated....
    Mine will be similar to this as my battery has been relocated to boot....I just need 63 to 75 silicone for my Throttle Body...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    ....and more recently...
    <tuffty/>
    Jul 2010
    Teesside
    933
    <tuffty/>
    Nice....
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by s3gazz View Post
    forge motorsport?! and a two figure price tag?! 27? as in, 2 and a 7? thats it?
    slowcoach3 likes this.
    Jul 2010
    Teesside
    933
    There £33 with the Vodka And Tonic.....
    Jun 2009
    Leeds
    3,469
    Chill guys
    I have one made up for mine but just not fitted it as i hate taking the bumper off and was going to change it when i get a new bumper as mine has a bit of damage to it
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,175
    who needs to chill? eh?
    www.badger5.biz
    bill@badger5.co.uk
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Double figure price tag......mine cost me a bit of free time at work ; )
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    would that happen to equate to say, the cost of a crate of your prefered lager?
    Aug 2010
    bradford
    1,252
    Looks nice does that pipe. Ill be buying the forge one and adding some extra pipe so we will see why happens in a few week along with a large port inlet and Wmi
    Jul 2010
    Teesside
    933
    Me to I have this one and 75mm Throttle Body....
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by cecilthesausage View Post
    I don't fancy paying all that money for a inlet mani lol so ill make my own with some AEB runners and my s3 standered inlet
    Jul 2010
    Teesside
    933
    Lol..... I'm in that deep now mate a bit more doesn't really make a difference anymore.....
  28. #27
    Aug 2010
    bradford
    1,252
    Lol pal might as well ha
  1. anyone got a spare s3 map sensor pipe
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2010, 21:56
  2. map sensor??
    By johnanderson in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2006, 17:50
  3. Irratic Idle - MAP sensor?
    By StanboA3 in forum Tuning
    Last Post: 31st August 2005, 20:40
  4. MAP sensor or MAF sensor
    By imported_stanA3turbo in forum Tuning
    Last Post: 17th August 2004, 23:09
