Has anyone got any experince with of these?
im running the madmax valve but it seems to be unpopular.
Ive heard it takes over -20psi (vhg is it) to crack the valve but i run it in a dv relocation kit and have it so the valve has the boost on its base, so this combined with the vacuum seems to open the valve fine, the only time i notice the flutter noise is at low speeds etc when the boost is minimal or has t kicked in.
I know the forge valve ports are around 5mm bigger in diameter and i believe the boost chamber is bigger but will i. Otice and improvements?
the mad max valve is exteremly responsive and holds boost far better than the 008 valve.
Anyway story over, is it worth upgradig as i can get the forge valve for under £100?
