EM TuningJMB Retrofits
Results 1 to 28 of 28
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    S3 door blades wrapped.
    Diy door blade wrap, carbon look.
    Before & after
    Fitted ...
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    looks pretty good mate :-) how long did it take?
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Good job.
    That looks quite interesting. What's it like from afar and have you tied it in with the grills?
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    Wingnut Express's Avatar
    Audi sponsored by Mastercard
    Feb 2008
    Surrey
    125
    Looks tidy, nice one
    Worried that one day I may have to buy something sensible, but until then!
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I took the blades off a few days ago and washed them, was about 15 min to remove them.
    It took about an hour and a half to wrap both sides and fit them back on the car.
    I haven't done the front and rear bumper inserts yet, but I plan to. It might be a bit more difficult but will give it a go. Will post some pictures when this is done.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Looks really good. Top job!
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Apr 2012
    30
    how easy are they to remove from the car?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Excellent, well impressed with that.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Thanks guys.
    The blades are very easy to remove. The door piece has 4 screws on the inside of the door, 2 screws are covered with rubber grommets and make sure you use a magnetic screwdriver or these 2 screws will fall inside the door and require the door card to be removed to get to them. After removing the screws you will need to knock the blade towards the rear of the car. I used a rubber hammer, tap the blade on the front corner until it slides backwards. Gently though!
    Rear blades just slide off, no screws here. Again you need to knock the blade FORWARD this time.
    If you do drop the screws in the door, I would leave them there until you ready to fit the blade back, then remove the door card. It will be easier to get the screws in with the door card off and you only need to remove the door card once. Best thing to do is use a magnetic screwdriver, less hassle!!
    Mar 2012
    131
    Looks great and the magnetic screwdriver is a good idea ! I plan to take mine off soon to re-align them so this information helps ...
    Martin
    S3 2003 Avus Silver, Sunroof, Chrome Mirrors, Symphony II, Cruise, Heated Seats, Centre Armrest, Ambient Lights, GTRS Turbo, Forge FMIC, Sports Cats, MillTek, Coilovers ...
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Glad to help Martin, but I can't take the credit. I read someones post of how to remove the blades and he mentioned a magnetic screwdriver. I don't have a magnetic one so door cards off for me
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    +1 on the mag screwdriver lol.
    Top job dude look great!!!
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by damo.h View Post
    Or if you don't have a magnetic screwdriver then you can rub your screwdriver with a magnet for a few seconds which makes it magnetic for a while.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,380
    That does look good I was considering doing this but also de chroming front grille too........
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    The front lower grill is now done.
    BEFORE
    AFTER WRAPPING
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Wheres the wrap from mate?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Also do you have to use a heat gun to manipulate the wrap?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I bought the wrap off Ebay
    eBay - The UK's Online Marketplace
    You will need a heat gun to get the wrap to sit nicely around corners. Its pretty durable stuff, heat it up, hold it in place untill it cools down and it pretty much stays in place.
    Rear bumper insert will hopefully get done tomorrow.
    Jimgrim77's Avatar
    Nov 2011
    957
    Quote Originally Posted by Scullies View Post
    Looks wicked ! Great job!
    Jimgrim77's Avatar
    Nov 2011
    957
    Was this the first time you wrapped Scullies? Been meaning to do mine since damo's incredible effort. Did you find it fairly easy? Any tips?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Any pics of it all fitted? Looks brilliant, propper good job. I doubt I could do it as good.
    How much did you need to do all the wrapping?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Yip, my first attempt at wrapping. The door blades were easy, the front grill is a bit more challenging. You need to be patient. I think the rear bumper will be easy as its all flat. Will need to remove the reverse sensors.
    Some tips,
    Always cut more than you need, you can always trim the excess off.
    If you do the lower front grill, start on the top and work your way to the bottom, don't do the top then the bottom and then try the centre. The material won't be able to stretch that much and will start to tear in the corners when you heat it up.
    I ordered 500mm X 2metre , but would suggest getting extra for trial and error.
    Pics to follow once fitted.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    S3 door blades, front grills and rear bumper insert wrapped
    Did a bit more wrapping,
    Chrome grill carbon fibre wrapped
    Before
    After
    Fitted to upper grill
    Fitted to the car, picture is crappy as the car is in the basement and the flash was bouncing off the number plate.
    Will get a decent picture up later on.
    lorryz's Avatar
    Apr 2012
    Brisbane, Australia
    114
    It looks good.
    I'm so glad you posted these pics.
    Nov 2012
    sutton coldfield north birmingham
    62
    sorry to bring this thread up again but i have ordered the same vinyl to do my door blades and grill surround. Is the grill surround done with i piece of vinyl ? if so any tips please ?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Yeah, surround is done with one piece. Cut the middle out and make sure you leave extra as you can always trim it off later. You will need a heat gun to do the corners to get the wrap to stretch.
    best advice I can give is start with the easy stuff so you get use to how the wrap takes shapes.
  28. #27
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    What if members cannot access a heat gun would a hair dryer do the same job albeit not as efficiently ?
  29. #28
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I think a hair dryer on full blast will work as the I used the heat gun on the lowest setting and it only takes a few seconds for the wrap to become soft and flexible.
  1. s4 door blades lower door mouldings
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th November 2011, 12:08
  2. S3 8L door blades / door fins (passenger & driver door)
    By The Doctor in forum For Sale/Wanted - Audi Parts
    Last Post: 6th October 2011, 12:46
  3. door blades
    By stuhow3361 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2011, 13:30
  4. door blades...help please.
    By cragga s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2010, 12:11
  5. S3 door blades
    By delboi1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2010, 20:44
