HOWTO: A must do mod - poly dog-bone mount!
SiGainey
North Wales
Howdo, Did a mod to the car last night which I was hoping would help with the gear selection problems I've been having recently... It's a popular mod on the mk4s and I'd not seen much about it on here, so I thought I'd give it a go...
There's no write-up to do as such on it as there's a really good one here for the MK 4 golf (Guide: Powerflex PolyBush Dog Bone Replacement - uk-mkivs) - the only difference is the S3 has a lower strut brace which is just a couple of 16mm bolts to undo and swing out the way...
I've been reading about the yellow powerflex bush giving a few too many vibrations into the cabin, so I went with PFF85-420R which is designed for the diesel engines but fits perfectly and there's no extra vibrations over OEM IMO...
Anyhow, the results... Well an annoying judder has gone when on/off light throttle in stop/start traffic, the gear selection problems have gone and it feels a lot tighter to drive. All in, for less than £20, it's a must-do mod and only took about half an hour to fit on the driveway with no special tools...
Good result then, i didnt know the s3 has a lower strut brace ....
lol, mine doesn't any more.... I had to cut mine off as the pinch bolts jammed and wouldn't undo from the subframe.
To be fair, it does absolutely nothing.
i may have a go at this. my engine moves back and forth a fair but thought it was down to my new found torque
if you wanted to go one step further too, You can also replace the front bush in the dog bone with a powerflex one.
I just picked up a set of INA track density engine mounts last night, and it's got the INA dog bone bush, and also a powerflex bush pushed into the front mount.
Expecting it to be really rather noisey once all that lot is fitted!
Yeah, I've seen the superpro front bush too but I wanted some refinement (it is an Audi after all ;)) but an improvement in driveline control. Works well :)
will PFF85-420R fit in the 1.6 guys? when i move slowly forward the car vibrates alot! and this sounds like the cure as al the engine mounts are ok. and whats the site called.any1 got a direct link to parts? thanks!! :D
I bought it from Awesome (and it's the last time I'll buy anything mail order from them) but it's any powerflex dealer - demon tweeks etc
sorry for ?'s but will this one be good for my 1.6? as mine rattles badlt and never new what it was until now Powerflex
I was under the impression that Tim aka 1animal1 hated this mod as it made the car vibrate awfully at low speeds?
Maybe on the yellow bush which has a higher shore rating. That's exactly the reason I went for the diesel bush as it should (and does) give you no vibrations...
Hello, I did use to have Yellow one fitted, but removed it after a few weeks due to a lot vibrations being felt in the cabin,
I might give the PFF85-420R ago as it does say on the web site "This bush is for the diesel engined cars, a softer material than used in PFF85-420"
Thanks for the info, I may also try half of the OE and half of the Yellow
Long delivery times and an apathetic attitude really - Ordered on a tuesday lunchtime for an in-stock item and they weren't even posted till the Friday so I didn't get them till post the weekend. When I spoke to them, their answer was they didn't know why it took so long.. :( Sure they are a very reputable company but their mail order wasn't my favourite - I order a load of bits off ebay and they always turn up the next day / the day after... You kinda get used to that great customer service!
FTR i hated mine, did what everyone above says...but mine juddered the dash at some junctions and became annoying - contemplated changing it just before i got rid - i'd never go polyflex again for a daily driver
Reactions: mattyb6
pipewerx fitted mine when i had their decat and 3inch downpipe they insisted on it.
if the diesel one is softer plus its only 20 quid then its got to be a winner over genuine audi one, not sure how much they are but i can imagine more.
you have to buy a whole new dogbone from the stealers as they dont sell the bush - £85 :)
so would people reccomend the softer deisal for a dailyt drive? as my engine moves alot at move off :(
I use the powerflex bush on my daily, and to be honest I don't see it as a problem at all.....
Vibrations arnt bad at all, but the improvement is well worth it
ok mate cheers. how much did u pick ypurs up for? ned cheapest with delivery lol they all fit any model 8l dont they.
do you need the powerflex dog bone small bush to go with the main mount? quite confused now lol
Yeap I see they dont listen to complaints & still at there old games, at least you got a reply.
Just fitted the R32 dogbone mount to my diesel and it was worth every penny, zero vibrations but you feel ten times more connected and in control.
I was amazed just how good the modification is
Hmmm....i'm not going to let rip here i'm going to choose to hold my tongue. But I will say this, I did hold Awesome right up there with the best, taking note of the "did".
By the way. I too have the Poweflex yellow from Awesome, it does vibrate a little more at lower speeds, but it's worth it.
G
Yep that very one. To be honest with you I had so much done at Awesome GTI (6k spent) that it's hard to tell exactly what made what difference, it used to be notchy going into second gear, but thats one thing that seems to have gone now.
G
G
Yup, same for me on the red one. Each to their own and I'm not knocking what anyone else has done but the red one seems to be a good compromise for refinement and improvement. Sure the yellow one would be ideal on a track car, but on a road car where refinement is important, the red seems a good option :)
764
778
26
6K
11
2K
