wipers :(
pthackeray22
well the wipers now come on there own when i first start the car, and never go back to there original stop position, HELP HELP
remove the wiper arms from the car, start the car up or turn the ignition on, let the wiper linkage move down and settle, re-fix your wipers on in the correct position and you should be ok! may be a weak, worn linkage, or has the car recently had a screen fitted and the wipers not put back in the correct place etc??
as soon as i turn the ignition on they start automatically then stop but in the wrong position ive let them settle, and moved them but still dont sit right they stop in a different place 99%of the time could it be possible relay issues?
It could be the switch, so even when your wiper stalk is in the off position, your wipers are on all the time?
no they wipe maybe 10 times then stop in as there off but always in the wrong position, then if i squirt or something a few times it sometimes goes in the right place
A wiper relay would be really cheap so won't hurt to try it, but my money would be on the switch, if it was the motor I'd imagine it'd do it all the time! Once the wipers have stopped have you tried to ever so slightly moved the switch about to see if anything happens? Also does the rear wiper come on? Last thing when the wipers park after first turning the key do they park in the correct place?
i shall try moving it slightly tomorrow, erm no rear wiper dont come on never tried it tbh, no they very rarely park in the correct place normally in the middle of the screen
I'm almost 100% it's the switch! If it was the relay it would stay on constantly as its either on or off! So I'd go for a switch!
9
922
665
865
