will this sit too high?
skanky Aug 15, 2006
  1. skanky
    skanky Member
    387
    got a A3 1.8t sport and getting a set of 17" alloys from an s3, will my car look like its a 4x4 and need lowering or will it look alright?
  2. millsyd
    millsyd Member
    114
    it should look ok your car will sit around 15mm higher in the arches than a standard s3.
  3. Olly_K
    Olly_K Administrator
    2,678
    yep it wont look too good, I always lower my cars first and buy alloys later.
  4. skanky
    skanky Member
    387
  5. Olly_K
    2,678
    no it wont look that bad, but i think your car would look better on the standard allows, but lower, rather than better alloys and higher.
    Thats just my opinion, you gotta do with what you feel's right !
    this was my golf on standard suspension, with 17" BBS on:
  6. skanky
    skanky Member
    387
    well the 16" alloys are pretty scuffed/corroding a bit (its a 2nd hand car you see), so i've got the opportunity to get some better alloys whilst not straying too far from the audi look, which is good for me.
    worse case, i can get it lowered at a later date! :)
    i'd be going from 205/55/R16s to 225/45/R17s tyres.
  7. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Here's mine with whatever suspension is fitted to a sport-spec A3 as standard sitting on S3 rims...
    Regards,
    Rob.
    (Click for higher-res)
  8. skanky
    skanky Member
    387
    how much is that lowered by? thats quite nice how it sits.
    i was thinking of maybe getting them refurb'd/respray'd in possibly anthracite, i think more black is just overkill given what my car looks like.
  9. FactionOne
    3,272
    183
    Like I say, it's standard suspension for a sport model...
    As far as I've always been lead to be believe, that would mean that it's about 20mm lower than a base-spec A3 - I don't know how an SE fits in (I'd guess there's just an old-person friendly blamange in each corner in place of a spring and damper) - Also, I'm not sure how much (if any) lower an S3 is beyond a sport-spec A3; there seems to be a range of opinion on this - I've still never seen anything printed in Ingolstadt which proves any of the theories though.
    Anyway, long story short, your turbo-sport will have the same height suspension as mine from the factory, so in theory should look exactly the same as that photo with the Avus rims fitted...
    Regards,
    Rob.
  10. skanky
    skanky Member
    387
    oh right, i need to learn to read for some reason i assumed was an adjustable suspension that you had, thats good cos i like the look the alloys on your car.
  11. FactionOne
    3,272
    183
    No worries, and thanks!
    I'd be a fibber if I said there weren't times when I'd prefer the wheels an inch bigger, and the suspension about an inch lower; but I'm still pretty pleased with it, and it's a whole lot better than it was with its 15"s on.
    Take it easy,
    Rob.
  12. roy_barber99
    roy_barber99 Member
    161
    if thgat photo is anything to go by it will be fine, i know suspension will settle a little aswell.
  13. silver75
    silver75 Big Ron
    3,265
    Allways thought A3 sports were 30 mm lower than standard.. 17s will look fine on a sport as later cars had 17 inch wheels on as an option and they look ok to me. Obviously it will look better lowered but i think you can get away with it on standard.
  14. Tallpaul
    Tallpaul Member
    835
    With the change in aspect ratio of the tyres the overall diameter of the S3 wheels and tyres compared to your original 16" ones will be exactly the same (OK, maybe a few mm differant). It won't 'sit up' on them at all.
    No harm in lowering it a bit though :cool:
