white wax spots left in stone chips
markie A3 Mar 6, 2011
  1. markie A3
    markie A3 Member
    149
    Its probably been asked before, but I detailed my car today. and the tiny stone chips are now all white. will quick detailer remove them without damaging the wax? or whats best for this?
  2. tdia4
    tdia4 TDIPOWARRR
    613
    Cotton bud with bit of apc on or a toothpick will work.
  3. markie A3
    markie A3 Member
    149
    They are in the lacquer and although not really visable prior to waxing, there are too many to use those methods fella, but thank you
  4. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    depending on how deep they are, i have wet flatted car paints to even the lacquer surfaces, then used the mop to polich it up, but like i said, depending if its just lacquer damage or paint damage, you can get away with using the OEM paint sticks to replace any lost paint, let it dry for a day, wet flat that to make the layer even and then mop it and buff it,
  5. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    I know this is an old thread but i was going to start a thread with the same title so may aswell use this one......lol
    When i first got my car (a3 ming blue) the paintwork looked perfect. I thought i would give it a wash and wax but the only wax i had was an old tin of triplewax (never used it).
    After waxing the car i noticed that the wax had made all the little stone chips stand out white (It took me ages to get it all out).
    I've just bought some SRP to use after i clay the car, but I've been reading that this is prone to leaving the car with the same white dots.
    Is this true and if so what can i do to prevent it?
    I've heard that meguiars polish would be a better choice?
    Thanks guys ;)
  6. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    When polishing or waxing any car you should applying the wax in thin layer's making sure you allow the wax to dry 100% before buffing off.. Buffing off Polish or Wax should be done with very little effort, on dark colour'S use a wax like dodo juice purple haze or blue velvet as these waxes are coloured.. We have loads of people asking "how much polish and wax should i use" the key is to apply each product in nice even thin coat's.. TIP : If you use a shed load of polish,glaze,sealant's or waxes on your car and find it hard to buff off you are using to much product.
  7. A3 T
    1,077
    15
    Thanks for the reply mate ;)
    So are you saying that the reason behind the white spots is just me using too much product?
    Or should i swap the SRP for some meguiars deep crystal polish, as it says its for dark cars?
    Thanks again mate ;)
  8. CMD
    3,015
    17
    The Polish has filled the stone chip. Remove the polish from the stone chip using a toothpick (be careful).. Your car is Ming Blue so the colour is Dark so any Dark Wax will be fine after polishing.. AG SRP a so so product..Megs DCS is part of a 3 step system polish set if i remeber.
  9. weela89
    weela89 Member
    64
    Panel wipe got the polish out for me no probs :salute:
    Failing that, toothpick FTW
  10. A3 T
    1,077
    15
    Thanks again guys.
    I've not had much luck with toothpick methods......lol
    I bought a touch-up kit from halfords and read that its best not to use the brush that come with it as it can end up leaving a blob on the paintwork and it best to dip a toothpick in the paint and gradually build up the paint on the car.....
    The only problem is the paint wouldn't come off the toothpick onto the paintwork....LOL
  11. StateOfPlay
    StateOfPlay Well-Known Member
    2,257
    192
    WD40 and then start again.
  12. mrpeng
    mrpeng 2.0T Quattro
    78
    i use yellow carnauba wax on my dark paint there no white in it at all looks mint check ebay for harley wax woods automotive is the seller i buy it from best stuff i have ever used
    cheers
    Lee
