Which OEM Bluetooth
purple8 Mar 4, 2013
  1. purple8
    purple8 Member
    67
    Iam looking to retrofit bluetooth module .
    I notice they have various letters on end. A, B, E , etc etc
    will any do are some to be avoided. I read somewhere some have limited functionality. What does this mean. Ie what is the functionality limited too
  2. NHN
    29,341
    1,719
    Some modules wont allow comfort features, like call lists through say the rns-e head unit, if you want full compatibility with the latest handsets aswell, then fit the newer modules.
    I can supply/fit this system if interested, the latest version aswell.
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,747
    656
  4. purple8
    purple8 Member
    67
    Ah so that's why the E ones seem such a bargain on eBay etc, what exactly is limited function though, I only Really want to safely receive calls. How much are newer ones with leads etc, baby due in Aug so want to save and fit before then.
  5. NHN
    29,341
    1,719
    Yes but if you have a modern handset then it may have issues connecting to an older unit.
  6. B5NUT
    3,747
    656
    (Should add if you have nav - RNS-E limited function = it just don't work). You get a message on the nav screen saying something like insert sim, if you get a compatible unit, you get access to, received, missed, and phone book.
    You also get this nice GUI with a compatible module.
    If you don't have navigation, then you don't need what I have said, however the D module is almost 9 years old and it would have very old software as NHN says.
  7. purple8
    purple8 Member
    67
    No RSNE just dual din concert . Would love rsne but budget won't allow now with baby on way.
  8. B5NUT
    3,747
    656
    So you could go for the D version but cannot see the point, I take it you have Multi-Function Steering Wheel?
  9. purple8
    purple8 Member
    67
    yes purchased but not fitted yet.
    It all depends on if I get much cash work.. I'm not adverse to a little diy. But it would take me half a day fit and I could spend the same time earning to pay a pro :)
  10. B5NUT
    3,747
    656
    Do you have a compatible steering wheel control module?
    The Audi BT system is pointless unless you have either RNS-E or MFSW
  11. purple8
    purple8 Member
    67
    Not had chance to check module yet, do you mean compatible with then blue tooth
  12. B5NUT
    3,747
    656
    no compatible with your new steering wheel, you have to have a steering wheel control module that works with the mulitfunction wheel, you also need a slipring which is compatible with MFSW.
  13. purple8
    purple8 Member
    67
    Not had chance to check yet. Trying to find the post that had part numbered to check
  14. B5NUT
    3,747
    656
  15. purple8
    purple8 Member
    67
  16. B5NUT
    3,747
    656
    If you have cruise then you should be OK, but you will need the slipring.
  17. OxfordRich
    OxfordRich Collecting Rings VCDS Map User
    112
    9
    I have OEM bluetooth and loom you can have, make me a sensible offer. If you have an iPhone 5 it won't remember the volume of the car when you stop the car and start it again; thats why I upgraded to the latest revision. I'll post up which version in a bit, get in touch if interested.
  18. OxfordRich
    112
    9
    Yeah it's 8P0 862 335C and loom, and bluetooth antenna and mic, so everything you need (although it'll need coding to your car with VCDS for 100% compatibility.
    Like I said, if you have an iPhone (or probably other new generation phone) it's not capable of remembering what level you set the call-volume at last time you used it - it defaults to 100% each time. It annoyed me so I upgraded.
