Wheel and tyre advise
V8Guzzler Nov 23, 2011
  1. V8Guzzler
    V8Guzzler Active Member
    584
    26
    One of my tyres keeps going flattish, ideal running psi is 39 and it slowly goes down to about 21 psi and stays there. This is wearing the inner and outer tread! Kwik fit say its a leak around the rim and there is nothing they can do?! Can anybody let me know how to solve this please, as I am spending alot of time at the air pump (and they are not free anymore) thanks :)
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    kwik fit are full of **** go somewhere else
    my brother is a tyre fitter and there is always something that can be done
    ask someone to whip the tyre off and clean the rim and refit with a new valve too you could also mention some rim sealant too which will help or even stop it :)
  3. moggie93
    moggie93 Member
    96
    Typical of them to say that.. Take your wheel somewhere else.. The coating on the inside of the wheel is probably flaking and this is where the air is escaping.. A reputable garage will usually clean this up with a wire brush and they then use a black bead glue to solve the problem..
    Hth m
  4. V8Guzzler
    584
    26
    Thanks gents I will go elsewhere tomorrow :)
  5. marktdisport
    marktdisport Active Member
    1,195
    15
    take the rim for a quick refurb and get the rim cleaned up were the tyre sits
    kwik fit !!! they are obviously the boys you cant trust lol
  6. scottshere
    scottshere Member
    369
    17
    39PSI, isnt that a tad high?
  7. jutlis 3.0
    jutlis 3.0 Member
    211
    39 is as stated by handbook for 235/40/18 i believe, as said remove tyre clean a bit and reseal on the rim.
  8. quattrojames
    14,068
    585
    39 would be about right for the V8 I expect, I run mine at 36.
  9. rezulteo
    rezulteo Site Sponsor Site Sponsor
    233
    15
    Hi there,
    The best thing to do would be to check where the leak is coming from. It would be a shame to get anything replaced if you don't need to, this kind of problem could come from the valve or the rim. A good thing to do may be to plunge the whole wheel and tyre into water and see where the bubbles are coming from. Failing that, try soapy water around the rim to see where bubbles form! The you'll know exactly where the problem is coming from!
    I hope this helps you out!
  10. V8Guzzler
    584
    26
    I put some tyre weld in and it has sealed the leak.. Good times.. 👌👀
