WHATS GOING ON M.P.G A4 TDI NOT GTI!
vw754 Jan 26, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,352
    58
    Filled up to the top,from shell (86.9 pece per litre) drove nice and nomal(no heavy right foot used) did 100.3 miles,went back to shell cost me 19.00 pounds! to fill up again!
    Whats going on,new temp sensor fitted fully serviced,it does take a few seconds to start,but only sometimes weather engine is hot or cold,will this make a difference? plenty of power in the car. Im sure it should of used no more than 10 pounds.
    HELP! A4 TDI 130BHP AWX ENGINE 2001 (B6)
  2. bubstar
    bubstar Member
    550
    Just over 20 mpg in English then....
    Doesn't sound right at all!!
  3. DIPS_A4
    DIPS_A4 SEAT LEON CUPRA R (225)
    570
    Ive had the same problem using shell extra diesel as well poor mpg filled up with bp got better mpg strange i wonder whats up with shell diesel :uhm:
  4. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Yes you should be getting double that, about 10 miles to the £1.
  5. WilkoS5
    WilkoS5 Member
    166
    You're right I get 100 miles out of a tenner and mines a quattro!!
  6. vw754
    2,352
    58
    i thort shell was good,ill try a different pump,see if that makes a difference!
  7. AndyMac
    9,832
    46
    The fuel will make a slight difference, but no way will it transform a car from 20mpg to 48mpg
  8. vw754
    2,352
    58
    temp sensor is new (4 week old) on vag-com temp reading was 80'C and on gauge was 90 ,is this a problem,if so whats the cause as sensor has been replaced?
    Also where is the thermostat located,is it a simple job?
