water in footwell, part 2
deejames Jan 13, 2014
  1. deejames
    deejames Member
    71
    following on from my other thread regarding windows opening and wet foot wells i`m trying to trace the source of a leak, does anyone know if there is supposed to be a cover across the back of the engine bay were the battery is? The car is a 1998 A4 Avant 1.8 photo (1).jpg
  2. Sulli79
    Sulli79 Active Member
    541
    37
    Not on cars before 1999, looks ok, do you have any standing water under the battery?
  3. Sulli79
    541
    37
    Also have you checked where the central locking pump is for water?
  4. If you have water in the passenger side footwell it will probably be from the joint on the rear washer pipe.
    Take the kick plate off at the bottom, below the glove box, you'll need to pull the door seal away a bit. You'll see the pipe which should just push back together.
    If you're not getting water from the rear washer jet that's most likely the cause.
  5. deejames
    deejames Member
    71
    i`ve not had the battery out to look properly yet but it looks damp as apposed to soaking wet
  6. deejames
    deejames Member
    71
    cheers, i will check that - it was a lot of water though, after the big storms a couple of weeks ago i came out to find both front windows down so i suspect it might be a leak somewhere but i will still have a look
  7. deejames
    deejames Member
    71
    where is that located?
  8. Sulli79
    541
    37
    Drivers side rear behind the trim, it's tucked down below where the rear lights are, it controls Windows as well so be worth checking it's all dry down there
  9. deejames
    deejames Member
    71
    cheers for that i will check
  10. aragorn
    18,545
    865
    First place to look has to be under the battery.
    There are two drain holes, and they get clogged, which means that plenum area fills with water and overflows into the car.
  11. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    Ah balls, I have a b6 too but didn't realise this also affected the b5. I just sorted my b6 plenum area, the battery was standing in about 4" of water :(
  12. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Also worth taking a look inside your ECU box. I found water and **** had been leaking under mine as the gasket had failed.
    Nasty!
  13. crazy88
    4,939
    437
    That's my concern with my b6. There's water in the drivers footwell, I'm hoping it was from the plenum chamber, but I suspect it may be from the ecu. Looks like it's in almost the same place on both the b5 and b6.
  14. jcb
    jcb Active Member
    4,132
    13
    every audi I hve owned from 90 through B5 C5 has had this problem
    irritating
    leak through ECU hole
    leak through pollen filter
    leak through rear avant indicator seal (C5)
    leak through upper window seal
    useless!
  15. deejames
    deejames Member
    71
    thanks for the advice everyone, i will take the battery out and check all the other things mentioned as well
  16. Blue_Thunder
    1,776
    33
    Ed, when you say leaking through the upper window seal, are you talking about windows, windscreen or rear screen?
  17. matt_simo1
    matt_simo1 Member
    79
    Check where the cabin filter is situated ...there should be a plastic water drainage piece situated under the window and above the cabin filter housing... Mine was broke and leaking water directly into the fan behind the glove box! Good luck
    deejames likes this.
  18. PaulJC84
    PaulJC84 Owner
    2,919
    17
    I would checl the seal around the pollen filter as some people can be a bit rough when replacing it and the seal goes.
  19. Broken Byzan
    13,237
    465
    My leak was from the pollen filter housing. I dried the seal out. Silicone it into its slot and smeared sealer around the face . As I had previously cleaned the mounting face I just glued it back on
