VCDS Security Access Code - Audi A1?
vagcat May 29, 2011
  1. vagcat
    vagcat New Member
    Hey guys,
    I am trying to get into some settings in VCDS to change the brightness of my DRLs on my Audi A1.
    It is asking for a security access code... From a bit of research normally there should be a pop up bubble that tells you the number, but this doesn't happen.
    Does anyone know how to find the code or does anyone know it?
    Thanks. :)
  2. NHN
    29,577
    1,779
    What version number of vcds are you using & is it genuine or counterfeit?
  3. vagcat
    vagcat New Member
  4. NHN
    29,577
    1,779
    & the rest of the question?
  5. vagcat
    vagcat New Member
    I am not sure, as i have borrowed the cable to change settings.
  6. NHN
    29,577
    1,779
  7. vagcat
    vagcat New Member
    Ok thanks, i will try that. :)
  8. vagcat
    vagcat New Member
    Still no go... It is a authentic cable by the way. :)
  9. NHN
    29,577
    1,779
    Please show us a screen shot of the page where its asking for security code.
  10. vagcat
    vagcat New Member
    Will that be able to tell you the code?
  11. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    If it did I'm sure NHN would have told you. Need to see where you're looking for the access code.
    If the 'bubble' hasn't popped up with the code, you're either not supposed to know it or RT havent had their hands on the module yet to map it.
  12. NHN
    29,577
    1,779
    Please show us the screen dump.
  13. a8 tech back
    a8 tech back Member
    198
    you need to screen dump what your doing so it can be seen and help given
    post a dump of address 09 long code and adaptation channels etc
  14. a8 tech back
    a8 tech back Member
    198
    Go to address 09
    Long code helper
    Change byte 24 for drl dimming
    Sent from my iPhone using
    My fat fingers
  15. rafaelbrener
    rafaelbrener New Member
    Hi NHN, im searching for the codes to unlock vim on my Audi A1. In Advanced ID doesnt appear tge serial number to insert in the software created by trick 77. Can you help me to find the codes for security acess?
    Thanks a lot
  16. rafaelbrener
    Dear NHM im trying to find a way to unlock vim on my Audi A1 - Can you help me? Im using an original VCDS cable and software. Thanks a lot.
  17. NHN
    29,577
    1,779
    Show me a log of your car please.
  18. h5djr
    9,463
    1,770
    Another item in connection with VCDS on the A1.
    With the A3 it is possible to change the instrument lighting using module 17 Instruments and changing the last digit of the seven digit code to a 4. This gives Needles ON Scales ON.
    The list of options with the seven digit code are:
    xxxxx?x
    0 = Seatbelt Warning Inactive
    xxxxxx?
    0 = Needles OFF and Scales Off
    1 = Needles ON and Scales Off
    2 = Needles OFF and Scales ON
    3 = Needles ON and Scales ON (Dimming active)
    4 = Needles ON and Scales ON
    Does anyone have access to an A1 and the correct cable to check if this works on the A1. We have taken the car to the dealers and they could not work out how to do it!!. The also contacted Audi UK who said it could not be done, but it seems to use the same J285 module to control the instruments as the A3. Maybe they are right but it would be rather nice to prove them wrong and get it to work.
  19. AudiA1
    AudiA1 New Member
    Hey guys,I am trying to get into some settings in VCDS to change the brightness of my DRLs on my Audi A1.
    The version number of vcds is 11.2
    And my cable is authentic.
    Thanks.
  20. AudiA1
    AudiA1 New Member
    Hey guys,
    My vcds version number is 11.2
    and my cable is athentic.
    Thanks for your help
  21. gary3306
    gary3306 Active Member
    989
    41
    3 posts from Nigel asking for a screen dump of the log. I have a sneaky feeling he might not post in this thread again........:noway:
  22. NHN
    29,577
    1,779
    & again, I like to help where I can, but you have to help yourselves please, POST A SCREEN DUMP of the said warning & log of your car, that way it provides us with allot more info to be able to look into the issues.
  23. AudiA1
    AudiA1 New Member
    Scuse me NHN but i don't understand...
    Do you want an image as this?
    I wait your notices
  24. AudiA1
    AudiA1 New Member
