VCDS meas. block log is only in one column
Excellion
Hey,
My VCDS logs ( no matter what i log) come only in one column while viewing in Excel and i cant make graphs out of it. Is it me being a noob on excel or theres something bad with the logging itself?
All of the information only in the A column.
I take it you mean the data logging graphs that move?
If so you need VCSope which comes as part of the latest download iirc.
No i mean that i want to make an excel graph with the log information, but all of the information is in only one column and i cant do that. All the logs i have seen each piece of information is in a seperate column
load the file into excel as a CSV file.. should look better....
As above the file needs to be saved and opened as a .csv file.
http://www.ross-tech.com/vcds/tour/logging.php
Looking at the image you posted all the info is there but it's not being displayed correctly in excel.
Also when logging multiple measurements you need to tick the group UDS option or Turbo option to get a decent sample rate. You look to be only getting 2 samples pers second at the moment.
It is a .csv file thats the whole point why i posted this thread. Sorry if i wasn't clear on that :)
