VCDS experts
Rudedaubin Jun 26, 2013
  1. Rudedaubin
    Rudedaubin Member
    78
    9
    Calling all VCDS Guru's.
    Is it possible to disable the front sidelight bulb out warning but keep the bulb failure system intact for the rest of the bulbs?
  2. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Coding out bulbs would be ridiculous so, why???
  3. Rudedaubin
    Rudedaubin Member
    78
    9
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Put resistors in line so the car thinks it has bulbs?
  5. Audi Doodah
    377
    35
    Was gonna suggest the same!
  6. vivalacoulter
    vivalacoulter Active Member VCDS Map User Audi S5
    409
    61
    Don't forget resistors generate heat depending how long they're used!
  7. Rudedaubin
    Rudedaubin Member
    78
    9
    I did think about resistors but then I'd have to find some way to mount/protect them , which isn't a problem , but if coding is possible surely it'd be the better solution.
  8. Audi Doodah
    377
    35
    Resistors generate heat depending on how much current flows through them...much like a bulb. Time is not really a factor as current flows in an instant. If heat is an issue a bigger surface area will help to dissipate excess heat.
