Various ABS / Brake / ECU Error's Does anybody know how to sort ?
sc00byd00byd00 Oct 3, 2010
  1. sc00byd00byd00
    sc00byd00byd00 Frank and Beans............... VCDS Map User
    230
    Had an issue on the Avant now for a while where when the car is parked up, the brake light are stuck on.
    (This is normally fixed by pressing and depressing the pedal)
    Its only started happening since somebody reversed into our car cracking the n/s rear tail light.
    Normally, i'd replace straight away but i've got a few financial things to sort first.
    On the way driving home today after noticing that the brake lights had been stuck on on walking back to the car, the ABS Warning Lamp lights up in addition to the brake warning symbol were lit whilst driving. then shortly after we started getting a flashing glow plug system warning light.
    This indicates according to the manual that there is a fault in the engine management.
    I've ran a full diagnosic scan using my VCDS and found the following; ( I was wondering if anybody could advise me of my next steps rather than taking the car to the stealers)
    (The left rear door not de-safing is unrelated to the brake issue, but wont unlock on anti-hijack deactivate, only unlocks via the unlock button on drivers door control system or key)
    VCDS Version: Release 10.6.1 (x64)
    Data version: 20100831
    Sunday,03,October,2010,13:29:48:12701
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E********* Mileage: 175890km/109292miles
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 8E0 907 401 N
    Component: 2.5l V6 TDI 0000SG 0006
    Coding: 02005
    Shop #: WSC 63251
    VCID: 3064F87FDA51
    Part No: 00006059
    Component: 130 106KC318_1.V14146724482
    WAUZZZ8E********* AUZ6Z0D0003157
    1 Fault Found:
    00741 - Brake Pedal Monitoring
    27-00 - Implausible Signal
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04455
    Shop #: WSC 06435
    VCID: 26481E27E895
    1 Fault Found:
    00526 - Brake Light Switch-F
    27-10 - Implausible Signal - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63251
    VCID: 63CE4733DB27
    No fault code found.
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 63251
    VCID: 3260F277D45D
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63251 000 00000
    VCID: 3E78D6471005
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01002
    Shop #: WSC 63251
    VCID: 438EA7B37BE7
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01401
    Shop #: WSC 00726
    VCID: 336EF7732B47
    WAUZZZ8E04A243080 AUZ6Z0D0003157
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
    Component: RNS-E HIGH EU H56 0650
    Revision: 42S Serial number: AUZBZ2F2114735
    Coding: 0419711
    Shop #: WSC 77801 146 52098
    VCID: 244C042F9EA9
    1 Fault Found:
    02005 - Coding Pin
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 183
    Time Indication: 0
    Date: 2010.08.10
    Time: 12:14:36
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDEAF13B3F7
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1412
    Coding: 02027
    Shop #: WSC 63251
    VCID: 73EE37736BC7
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0004
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0004
    2 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01561 - Left Rear Door
    61-10 - Won't De-Safe - Intermittent
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0419711
    VCID: 244C042F9EA9
    1 Fault Found:
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 183
    Time Indication: 0
    Date: 2010.08.10
    Time: 12:14:36
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
    Component: FSE_256x BT H38 0600
    Revision: 00000000 Serial number: 00000005169720
    Coding: 0011722
    Shop #: WSC 22782 000 00000
    VCID: 75EA096B65B3
    End ---------------------------------------------------------------------
    I've cleared the fault codes, and i've no doubt that when re-driven that the ABS intermittent fault will return and will more than likely just be a sensor (if not related to the Brake Light Switch - F)
    My only major concern is that the Glow Plug Light Warning is still flashing.
    Can anybody advise how I can further diagnose whats causing this ?
    Need to make arrangements for tomorrow as the Mrs needs the car (or a car) for work :(
  2. aragorn
    18,444
    848
    The codes tell you exactly why the ABS/Engine lights were on, your brake light switch is faulty.
    Replace the switch.
    You've probably been driving around for months annoying everyone else on the road with your brake lights permenantly jammed on.
  3. sc00byd00byd00
    230
    Brake Light Switch ?
    Easy to replace ? Is it dangerous to use the car ? I.e The brakes aren't gonna fail whilst driving are they ?
    Is the Brake Light Switch literally JUST a switch attached to the brake pedal that activates the brake lights ??
