TQS progress thread, From STD-Scroll-Eliminator.
Broken Byzan Nov 14, 2009
  1. Broken Byzan
    13,237
    465
  2. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    It's alive?!?! :D
    Broken Byzan likes this.
  3. superkarl
    superkarl MAN OF STEEL
    9,495
    2,436
    im one to talk but, tumbleweed......
  4. Broken Byzan
    13,237
    465
    Nothing to add just yet. Lol she has a puncture , er I need a cv gaiter and i'm gonna put oe cams back in and bin off the cats. Oh I need to make a water pipe but bill has been a bit busy so ill continue chucking g12 in. It's not pissing out.
    I think I'll oil change it then.
    She did make the rollers but it blew a pipe, while I was fitting it back on the battery went flat. Then the water leak was spotted so we gave it up as a bad job. Lol iirc she made 350 odd on the gtrs tune but didn't want more boost or timing despite there being room for both. This we believe is the fault of the cams hence the return to oe
  5. PaulJC84
    PaulJC84 Owner
    2,912
    17
    Just had another read of your thread.
    Are the parts you required to fit a TFSI K04-64 as follows?
    K04-64 with integrated manifold
    Manifold adaptor plate (supplied by beachbuggy or badger5)
    Badger 5 tune
    ECU swap to flashable ECU
    Custom downpipe
    Oil feed hose (off another Audi model?)
    Oil return hose (off another Audi model?)
    Coolant feed hose (off another Audi model?)
    Coolant return hose (off another Audi model?)
    3" Maf (from and S3)
    Custom intake
    550 injectors
    4 bar FPR
    Hose for turbo to IC (supplied by beachbuggy or badger5)
    Be good if you could add or correct any of the above please?
  6. Broken Byzan
    13,237
    465
    Adapter from BBt
    Any custom tuner
    Ecu management depending on tuner requirements.
    Custom dp to free flow exhaust.
    Oil feed is generic braided oil feed hose.
    Oil return is std a4 one with braid removed and an oil resistant hose clipped in.
    Coolant hoses from a4 can be used.
    Maf to suit tune - management
    Tip and filter to suit turbo and filter preference.
    Std fpr
    550 injectors or similar depending on tuners requirements
  7. aragorn
    18,444
    847
    Did you get the B5 coolant hoses to fit in the end then? I thaught you needed TFSI ones?
  8. Broken Byzan
    13,237
    465
    I used a combination of b5 turbo side banjos bent to clear and silicone. None of my pipes are as they came as I've hacked the **** out of them in the past. Lol one has the after run pump in line the other was shortened a few times as it split
  9. aragorn
    18,444
    847
    ah ok!
    So you recon stock B5 pipes would fit alright then?
    I guess the most awkward bit is the welding of the compressor housing for the DV, and the modifications to the turbine housing to clear the engine mount?
  10. PaulJC84
    PaulJC84 Owner
    2,912
    17
    What needs done for the DV?
    Can you not just locate that onto the cold side and pipe the blow off air into the intake pipe?
    I could not see the exact details in the pics on the last page.
  11. aragorn
    18,444
    847
  12. PaulJC84
    PaulJC84 Owner
    2,912
    17
    Ah I see. Could you just use a t piece and some hose and have it right after the turbo?
  13. Bradderz_1988
    3,958
    238
    You need it to recirc back to the intake or it runs rich as the metered air the MAF see is not there.
  14. aragorn
    18,444
    847
    DV has two connections.
    One goes after the turbo in the pressure pipework, thats easy enough to sort as you need a custom pressure pipe anyway, so you can just get a barb welded on.
    The other feeds back into the inlet of the turbo, in the pipe between the turbo and MAF. As standard the provision exists on the stock rubber hose between the two, on the TFSI this hose is completely different and needs made up by you, and thus doesnt have a fitting for the DV.
  15. Broken Byzan
    13,237
    465
    I only used the blank on the 064 because I could. Saved blanking it off and moving dv too far away
  16. Broken Byzan
    13,237
    465
    The tfsi std tip is just a 90 degree hose from air box to turbo with no inlets on it
  17. PaulJC84
    PaulJC84 Owner
    2,912
    17
  18. Bradderz_1988
    3,958
    238
    Looking at the tfsi setup were marks plumed it in is actually for the oil vapour breather pipe for the valve cover (puck valve on our cars) you could probably use a vacuum DV from forge designed for the tfsi turbo and do away with the 710N.
  19. PaulJC84
    PaulJC84 Owner
    2,912
    17
  20. aragorn
    18,444
    847
    The APR turbo isnt a standard K04-064.
    The compressor housing has been modified to take a factory DV, that hole isnt there on a real K04-064.
    Also, the factory DV that goes in that hole is electronically controlled, rather than vacuum operated like on the B5.
  21. PaulJC84
    PaulJC84 Owner
    2,912
    17
    Yeah I noticed the pic comparing the two housings.
  22. Bradderz_1988
    3,958
    238
  23. Broken Byzan
    13,237
    465
    I'm on a list waiting for testing. Lol. I know where a ko3 tfsi turbo is in very good condition. ..
  24. jaymodunn
    jaymodunn Member
    123
    can i ask, is the gt eliminator a worth while upgrade as it looks bolt on for around 900 pounds.
    i would be happy with 250 - 300 bhp.
    i know there are associated mods, but the eliminator seems a good package.
  25. aragorn
    18,444
    847
    for 250-300 i'd just get yourself a decent K03 hybrid.
  26. jaymodunn
    jaymodunn Member
    123
    The reason i ask is i guess a hybrid is maybe 700 but for 200 more you get a turbo that you would never have to upgrade again.
    I don't see the reason for a hybrid when the eliminator seems to offer a lot more for not much more?
  27. jamie226bhp
    jamie226bhp Member
    468
    I got a quote of about £470 from a place called bernies blowers on face book who came recomended from a few ford friends
  28. jaymodunn
    jaymodunn Member
    123
    that seems a good price, as i need to replace my turbo and a bex 1.8t turbo is 180 so makes sense to pay some more for an upgraded one.
  29. aragorn
    18,444
    847
    I dont really think the eliminator is any better than a hybrid. Your still stuck with the compromised stock manifold etc, so its not really as good as you think it should be. the housings also much more restrictive than a "proper" GT28 so it doesnt make the numbers.
    Mark also had two of them fail, so i'm not sure what that says about their reliaibility...
    250 is easily attainable with a hybridised K03, and with the right bits you'll probably get upto around 280ish.
    Speak to beachbuggy on here. He does a wide range of hybrid options at various price points.
  30. jamie226bhp
    jamie226bhp Member
    468
    Pm'd
  31. Broken Byzan
    13,237
    465
  32. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,109
    349
    Oh dear :sob:
    What now?
  33. aragorn
    18,444
    847
    Like i was saying on facebook, at this point i'd be bolting in a stock motor.
    If the turbos good, bolt that on and drive.
    If its not, use the K03 and flash on a stage1 map for now.
    Big fancy build is just pointless IMO when folk have made 400hp on stock motors (with rods)
  34. Broken Byzan
    13,237
    465
    Yeah. I need replacement rods regardless as I think the small end failure has contributed /caused this.
  35. docurley
    4,071
    86
    Ooouch sorry to see that if i had a thing that could help i would but engine parts i don't have.
  36. aragorn
    18,444
    847
    Small end failure?
  37. Broken Byzan
    13,237
    465
    The dm rods have had a slowly worsening rattle since not long after they were fitted. Seems to be a faulty batch
  38. aragorn
    18,444
    847
  39. slepy
    2,109
    349
    Jeez, that's bad!
  40. Broken Byzan
    13,237
    465
    probably won't be using these bores again either
