Don't no when your be looking for new brakes but I have penciled in around Xmas /early new year for bbk so my s3 brakes will be availableYeah I don't really fancy spending £1000 plus just to fill the rims and look pretty lol, I can get my hands on a used S3 set for around £400ish based on what I've seen on eBay.
To be honest it is the caliper I don't like, the S3 one looks much meatier...the discs on my car aren't a bad size.
And let's not even discuss the rears lol my gran has saucers bigger than those rear discs!!
They look awesome ! Will look better with clean wheels taking it straight back to amd for a new alternator?
Ok I'll do my best not to forgetHey..please keep me in mind when you take your S3 brakes of! I will definitely forget to please PM me or something?
Hopefully they do the trick turn the horsepower up now? Lol
Going to keep it under 600 bhp for now.
Exhaust needs doing before that and I've spent enough right now !
Alex, is the possibility of a DSG gearbox still being investigated/theorised about or is this something that will be happening in the future?
You will kick yourself if you go down the DSG route...for ever buying a manual car
Hope it's just the alt mate and nothing more sinister
Yes.
Andy at Storm is pricing things up and deciding which box is the most suitable.
They've already done a TTRS conversion using the Syvecs which already has software to interface with the DSG.
Later in the year perhaps.
Hopefully all goes well Alex, and that it's just an alt or battery issue!
Good glad it's all sorted and not to expensive ,first time you have replaced it? Mileage?dont the hazards take priority for safety reasons?Turned out to be the starter motor,which explains a lot.
Battery had voltage,but was dropping it sufficiently with a duff starter for everything else to drop out as well.
Hazard lights were OK though.....
Hi Alex, did you have to use spacers with the AP kit?
Happy to hear that as I now have same wheels as you.
I had a 2008 S3 stage 1 140k miles...replaced gearbox after crunching too many times, but nothing else. Didn't even change clutch. I had it from 60k. Caned it everyday. Track days, Nurburgring twice in one year...I must have been lucky...then some poor b*stard stole it!Mmmm mine is on 67k due to go soon then
Not that lucky if it got pinchedI had a 2008 S3 stage 1 140k miles...replaced gearbox after crunching too many times, but nothing else. Didn't even change clutch. I had it from 60k. Caned it everyday. Track days, Nurburgring twice in one year...I must have been lucky...then some poor b*stard stole it!
It was a blessing. I started my business with the money. Every cloud has a silver lining as the saying goes...Not that lucky if it got pinched
Brakes look decent ! And so they should for the money! On the tape will that not keep the heat inside the engine bay? or does it absorb it?
Is there a way you can re-route something off the air con to feed cold air under the bonnet? Or is that crazy and wouldn't work?Well.....it's a bit of an experiment.
I removed the sound deadening which really was getting properly ******,and thought the bonnet underside would only get more of the same,and the paintwork would suffer.
My old Sierra had a patch on the bonnet where the turbo was cooking the paint from below,and the paint had crazed and gone slightly off-white.
The other mod is to remove the rubber sealing strip at the rear of the bonnet,but only when it's dry...
How many miles do they recommend u bed them in for before giving them a caining ?I think it wouldn't work well!
The best solution is just better underbonnet ventilation.
Removing the sealing strip would help but does leave a gap for water to get in.
I'll see how we go for a bit while the brakes settle in.
How about some Saphire/EsCos-esq bonnet vents?I think it wouldn't work well!
