Think The S3 Has Some Stiff Competition!
emzino Mar 23, 2007
  1. emzino
    emzino Active Member
    1,231
    As the title suggests, were in for some rough weather as BMW unveil there new M3 V8.
    Details taken from PistonHeads (http://www.pistonheads.com/news/default.asp?storyId=16061):
    • 3999cc
    • 414bhp @ 8,300rpm
    • 295lb ft @ 3,900rpm (251lb ft available from 2,000rpm)
    • 8,400 max engine speed
    • Engine weighs 202kg – 15kg lighter than old ‘six’
    • Aluminium silicon alloy crankcase, iron-coated pistons run directly in the bores of hard silicon crystals
    • Bedplate structure
    • Crankshaft weighs 20kg – 5 main bearings
    • Oil cooled pistons
    • High-strength steel magnesium alloy connecting rods weighing 623g each
    • Single piece alloy cylinder heads with 4 valves per cylinder
    • Double Vanos variable camshaft control
    • Double chain-driven cams
    • Oil system works to 1.4G with 2 pumps
    • 8 individual throttle bodies. Accelerator pedal position monitored 200 times per second. Takes 120 milliseconds to reach maximum opening point.
    • No air mass sensor – ecu does the calculations from the range of data available to it
    • Two, 4-1 ‘fan type’ exhaust manifolds
    • 4 cats
    • MSS60 ecu – development of the one found in the V10 M engine. Three 32bit processors. Can handle more then 200 million individual operations per second.
    New M3 V8 engine specs
    Fuel - RON 98 (95)
    Max output bhp - 414 at 8,300rpm
    Max torque lb ft - 295 at 3,900rpm
    Max engine speed - 8,400rpm
    Stroke mm - 75.2
    Bore mm - 92.0
    Displacement cm - 33,999
    Distance between cylinders mm - 98
    Cylinder arrangement - 8-cylinder V-engine
    Valve plate diameter, intake mm - 35.0
    Valve plate diameter, outlet mm - 30.5
    Compression ratio - 12.0:1
    Fuel injection - Intake pipe fuel injection
    Fuel injection pressure bar - 3–6
    Average combustion chamber pressure bar - 12.6
    Maximum combustion chamber pressure bar - 100
    Engine weight to BMW standard kg - 202
    Output per litre bhp/litre - 103.5
    Crankcase - Aluminium
    Valvetrain - Infinite camshaft adjustment and hydraulic valve clearance adjustment for intake and outlet (double VANOS)
  2. mcmasman
    mcmasman Member
    152
    Shouldn't the M3 more likely compare with the RS4 instead? :think:
    It is definately going to out-run the S3 ...
  3. emzino
    1,231
    I thought it was like this:
    M3 = S3
    M5 = RS4
    and so on and so forth but just done some research and your right, it's direct competition with RS4 and Mercedes C63 AMG. My bad...
    But it is a cracking car! It's a tough on between the RS4 & the new M3. Hmmmmm
  4. DSGSport
    DSGSport New Member
    23
    I'm afraid not
    As far as I am aware it is
    1 Series = A3
    3 Series = A4
    5 Series =A6
    7 series = A8
    etc
  5. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    414bhp out of a NA 4 litre? That's pretty special!
  6. newbiecrg
    newbiecrg windsurfer
    1,328
    What does an M3 has to do with an S3?
    Give me an M3 anyday off the week....
    Maybe next year....
    Pedro
  7. Ess_Three
    Ess_Three Active Member
    5,383
    Not quite as special as the new GT3...claimed 418 BHP from a 3.6.
    Evo tested one at (I think) 427 BHP.
    That's even more special...
    But anything above 100 BHP/litre is special in my book!
    I can't honestly see the V8 M3 and the S3 going for the same target buyers...
    The M3 will be nearer RS4 money, if nothing else.
  8. Staz
    6,206
    67
    Ahh yes but 418 out a 3.6 is VERY special not just pretty lol
    Emzino made a mistake. He's changed the title to RS4 has some tough competition.
    Eventually we'll have to uprate the 100bhp/l threshold as better and better engines come out!
  9. emzino
    1,231
    That's right so please stop pointing out the obvious :keule::asskicking:
  10. Staz
    6,206
    67
    Hey no need for that. I'm on your side after you made a mistake thinking an M3 was a rival to an S3!
  11. joost
    joost Active Member
    1,169
    Regardless of what the M3 can achieve, it'll still be driven by a complete ****@r!
  12. emzino
    1,231
    I meant it in a sarcy way. Hard to show it when typing heh :arco:
  13. normski
    normski Member
    497
    I assume you didn't look at the price of the M3 before starting this one?
    But the S3 will certainly hold its own with the 335 and at £10,000 less.
  14. Staz
    6,206
    67
    but I'd expect a few more comments cos the title on the forum hasn't changed lol
  15. normski
    normski Member
    497
    Yeah, I think the M5 and M6 offer some stiff competiton to the A2 as well, think the A2 will struggle to keep up with these babies....
    Lol, stop taking the **** now everyone. He made a mistake and I don't think we should punish him any more.....ok just for today give him hell, but come tomorrow......give him some more:jump:
  16. a3norwich
    a3norwich Not anymore - Back 2 BMW (shh)
    359
    OI! I used to have an E46 M3!!!
  17. joost
    joost Active Member
    1,169
    But you saw the light...
    Only kidding fella, I've nothing against M3 drivers, past or present - it was just an alcohol induced posting, my bad :sorry:
  18. a3norwich
    359
    Hmmm, just a differrent light I think. Was getting a bit fed up with their dealers' arrogance. Seems I have swapped it for a different type of arrogance with my first Audi...
    Have to say though, BMWs don't have creaky doors, folding mirrors that have a mind of their own, central locking/door mirrors/windows that stop working for no reason, door alignment problems, etc, etc!
    "A characteristic of the car, sir..."
  19. newbiecrg
    1,328
    what? complaining about Audi "features"?....
    Pedro
  20. normski
    normski Member
    497
    And you still ordered an S3?
    I love BMW's as much as I have always wanted an Audi. We have some new 530's at work and the amount of piddly problems with them is unreal. Either a bad batch or standards are slipping everywhere.
  21. a3norwich
    359
    Indeed I did! A moment of madness perhaps. However, I don't think there's such thing as a perfect car. They all have their problems! My M3 ownership wasn't without "entertainment"...!
  22. emzino
    1,231
    I changed the title as soon as the 2nd post pointed out that the M3 isn't up against the S3 but theres a bug with the forums.
    When I change the title, it only shows the updated title once the thread is opened and not when it lists the threads in the 8P section... :idea:
  23. Spook
    Spook Member
    216
    If you're talking about cop cars, you should know that police fleets are made up of lemons in weird specs that their first owner rejected.......;)
  24. steve184
    steve184 Active Member
    1,138
    mmmmmm M3 - my next car - prob old shape - love em
  25. normski
    normski Member
    497
    Completely untrue with the BMW's, they don't even bother putting the seats in em any more to make space for the armoury, factory built to order and spec including wiring looms etc. for lights, and allsorts, plus they have such an odd spec that no-one else would touch them before us.
