The Stance Thread
pinterovski Sep 23, 2011
  1. NHN
    29,284
    1,695
    Yes you do need to remove headlining, they have special fixings for these to bolt onto.
  2. pinterovski
    pinterovski Member
    667
    88
    1) Picture of your car;
    2) Brand of Coilover/suspension/Air Ride;
    KW V3 Coilovers
    3) wheel and offset;
    BBS CH rims 18x8J ET45
    4) tire and size;
    Dunlop Sportmaxx 225/40/18
    5) spacer brand/thickness;
    Custom Alu spacers, Rear 13mm
    6) other info (fender rolling, replacement tie rod ends, etc);
    Removed rear arch screw and trimmed the inner edge!
  3. Ironborn
    Ironborn English...not so good
    1,177
    227
    Looks hot!:icon_thumright: What camera did you use? So much detail. Also what upload method did you use? Photobucket seems to be messing around with my picture quality
  4. scotta3tdi
    scotta3tdi New Member
    10
    1) A3 2.0TDi Sport 140
    Sport standard
    BBS replicas - unsure of offset
    4) tire and size;
    225/40/18
    None
    None (that I know of!)
    Just bought this so finding out about it as I go. Was planning on just adding a subtle drop, probably just 30mm springs which should give an extra 20mm drop on Sport standard I believe?
    pinterovski likes this.
  5. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    599
    102
    43
    1) A3 cabriolet 2.0 TFSI S Line
    S Line with H&R 50mm lowering springs
    OEM standard
    4) tire and size;
    225/40/18
    Front H&R 10mm I think to accommodate Forge 330 Big Brake Kit
    None
  6. pinterovski
    pinterovski Member
    667
    88
    KW V3 Coilovers
    OZ Ultraleggera 18x8J et45
    4) tire and size;
    Bridgestone Potenza re50a 225/40/18
    H&R Trak+, rear 13mm
    zyzio and S. like this.
  7. S.
    S. Well-Known Member Team Ibis TFSI Owners Group quattro Audi S3 Manual
    1,939
    500
    need some ultras :D
  8. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    Bilstein B16 PSS10 Coilovers
    BBS CH 18x8J et50
    4) tire and size;
    Michelin Pilot Sport 3 225/40/18
    None in the pictures. Now H&R Trak+, front 10mm, rear 15mm
    Nothing yet.
  9. S.
    1,939
    500
    ok then, here's mine :D
    kw v3's
    3) wheel and offset
    oem facelift s3 wheels 18x7.5 et54
    4) tire and size
    michelin pilot exalto 225/40/18
    dunlop wintersport 3d 225/40/18
    scc 12mm front
    nothing
  10. pinterovski
    pinterovski Member
    667
    88
    Sami on winter setup,looking good!
  11. S.
    1,939
    500
    thanks mate :D
    that's with summer tyres. actually with winter tyres it looks the same :D
  12. AUDI_ADDICT
    AUDI_ADDICT Member
    72
    17
    Not exactly 'stance', but hopefully will help others to know what difference just springs make..
    Pic before
    And after
    Eibach Sportline
    Wheel and offset
    OEM 7.5 x 18 ET54
    Tire and size
    228*40*18 Conti Winter Contacts
    Spacer brand/thickness
    None (yet)
    Other info (fender rolling, replacement tie rod ends, etc)
    Nothing
    I will also add it has taken away all the crashy ride it had before, and is MUCH nicer to drive now
  13. br20vt
    br20vt Active Member
    190
    55
    Airlift V2 suspension with performance struts.
    OEM Facelift wheels, Bridgestone tyres. :blink: (Just for winter).
    Jonathaan and pinterovski like this.
  14. GGG_666
    GGG_666 Black it out!
    207
    62
    Bring this thread back
    VMR V701 19x8.5" ET45 w/10mm rear and 8mm front spacers
    225/35 19
    BC Racing BR series coilovers with 10Kg springs
    Tay_GP, kash_v, saq85 and 1 other person like this.
  15. S.
    1,939
    500
    Liking that! Moaaaar pictures!!
    Compkiler and GGG_666 like this.
  16. saq85
    saq85 Active Member
    217
    50
    That looks baaad.
  17. GGG_666
    207
    62
    Like Michael Jackson bad or horrible?
  18. saq85
    saq85 Active Member
    217
    50
    Michael Jackson bad!
    GGG_666 likes this.
  19. Starry
    Starry S3 8P stage 2+
    333
    27
    just found this thread, very helpful as I'm looking for new wheels
  20. Donny_DJ
    Donny_DJ Active Member
    405
    107
    43
    Comparison of 18s vs 19s:
    Now:
    Eibach Pro Kit lowering springs. Thinking about fitting Sportlines - thoughts?
    3) wheel and offset
    Genuine RS3 alloys (8J x 19), ET50
    4) tire and size
    Goodyear Eagles, 235/35/19
    None. Thinking about 8mm spacers for the front soon though.
    None
  21. Welshy
    Welshy Member
    87
    37
    Wondering if I could have some ideas... I'm wanting some staggered Rotiform ind-t in in the new year ready for some shows only issue at the moment the rear option is the front: 18" 8.5j et45 rear: 18" 9.5j et35 will the rear fit? Don't mind a tad of poke but will lower as much as possible on those wheels.....
  22. Welshy
    Welshy Member
    87
    37
  23. josh2303
    josh2303 Member
    44
    10
    17 " PORSCHE TWIST
    8.5 J FRONT 9 J REAR
    205/40/17 ALL AROUND
    ET 35 i believe , running 30mm adapters all around not sure of brand
    fk street pro coilovers.
  24. Welshy
    Welshy Member
    87
    37
    tidy stuff! Didn't think people went for smaller wheels! Looks good though! I want to stick with 18" as the 19" I wanted were 10j so thought that it be a bit of hassle, maybe next wheel I go 19"!I need to see a pic of 18" 9.5j et 35....rear but no spacers
  25. josh2303
    josh2303 Member
    44
    10
    i only went for 17s as it was on audi s line alloys which were 17s when i got it.
    its going on air early next year and smaller wheels and air go well together i think , if i go bigger i need to find some thing with an offset that will give me some nice tuck. but thanks for the feed back mate :glee:
    Welshy likes this.
  26. GGG_666
    207
    62
    ET35 will rub/scrub on the rear
  27. Welshy
    Welshy Member
    87
    37
    That's **** lol!I been told it be fine, oh well!an ideas where the best place to get rotiforms would be? I prob run a bit of camber as I seen people with lass then et 35 and still fine hmm!
  28. josh2303
    josh2303 Member
    44
    10
    you can get rotiforms from car audio security or rim style i think
  29. Welshy
    Welshy Member
    87
    37
    Yeah I been looking on there but if I was to have staggered I think they are et35, you think if I gave them a call they would know fitment and that?
  30. S3Alex
    10,372
    4,413
    No belly-dragging here I'm afraid.....
    Also I have no idea about offset,so...
    kW Clubsport suspension with adjustable topmounts.
    H&R ARBs
    Superpro bushes and ALK
    TD 1.2 alloys 18 x 9
    Michelin Supersports or Toyo R888s 245x40x18
    Around 2.0 degrees negative camber on the front,and 2.5 on the rear.
    One dirty picture....LOL
    No rolling,no rubbing and no spacers.
    kash_v, HHS3 and Welshy like this.
  31. GGG_666
    207
    62
    no doubt you could get away with it with loads of camber but you'll run thru tyres like crazy, it always looks good but in reality it's not practicle. Are you running air or coilovers? I had ET35 and ended up chipping some paint off the wheel arch... I've since changed to a higher offset
  32. Welshy
    Welshy Member
    87
    37
    Yeah, well to be honest I think that's the only way to manage is camber but like you said it isn't practical but again the wheel will be for show use and my neighbour works for quick fit haha! But I think I'd prefer less hassle, I think for me et35 it a bit of a push and I like my paint lol! So what offset you running as you have some pokeage?
  33. GGG_666
    207
    62
    The pic I have up is from my ET35, I'm currently ET45. I had originally put 10mm spacers on for a car show and then left them on... that's how I chipped the paint. I could see doing it at a show then removing the spacers
  34. josh2303
    josh2303 Member
    44
    10
    @Welshy yeah mate give them a call they are a helpful bunch if not go on google and search for a offset calculator ?
  35. Welshy
    Welshy Member
    87
    37
    I see GGG 666! I would like too run them for summer and shows! Just et45 won't have any staggered fitment unless spacers grrr! Done an offset on will it fit and well seems ok but no idea on how much it will poke lol! I just want more concave on the rear... will call them Josh....
  36. Welshy
    Welshy Member
    87
    37
    Click on the image should get half an idea lol.....
  37. GGG_666
    207
    62
    4052.jpg This is my old set up, 19x9.5 rear ET35 and 19x8.5 ET35 front.... way too much poke
    20140601_153026.jpg Heres my new one 19x8.5 ET 45 front and rear (I also used spacers on this set up for shows)
    I get what you're saying, it's difficult to find the happy medium between fit and function but I think I finally got it. You'll have to do some thinking I guess
    Welshy likes this.
  38. Welshy
    Welshy Member
    87
    37
    See your point there! But have to say a bit of camber and those 35s would look good, but if I do go this way I have 45 front, yeah exactly my point! I can go 45 rear on the same wheels just no concave, either way once I have them I will do whatever to run them, that happy medium is a tough one as I like the perfect fitment only other way is laser cut lol! Will have to have a think for sure!
    GGG_666 likes this.
  39. Starry
    333
    27
    Are you running the spacers on the 2nd photo?
  40. GGG_666
    207
    62
    @Starry..... Nope just a good angle on the photo
    19x8.5 ET45 with 225/35 tyres
    Starry likes this.
