tdi head removal?
slowcoach3
Devon
Alright folks how's it going?
While my s3 is off the road I've got a little 110 bhp tdi. Which the head gasket has just gone on lol Changed plenty on a 20vt but this is obviously different, I don't have the correct timing tools to hand does anyone know if I can just release the tension on the cambelt and slip it off then worry about timing it all properly when it comes to refitting?
A bit piky I know but I'm in a hurry! Cheers
sorry to here that, prob get shot down for this cant you use some of that head gasket fixer stuff if its a throw away car??
other than that stand in a manhole and get someone to drive at you fast haha...
Haha Tbh I don't mind fixing at all, just don't have the correct timing tool yet but need the head of asap. Might just turn the crank to tdc using the flywheel, hold a bar on the crank and cut the ****** belt. At least half the engine will be tdc then :(
taking belt off should not be problem, but to be 100% sure of no contact, find TDC then rotate crank another 90 degrees to put piston at mid bore. this will ensure no contact
timing belt on the diesel is a bit more difficult to put back, you absolutely need the right tools and VCDS to get the timing fine tuned.
good info on the tdiclub website http://forums.tdiclub.com/forumdisplay.php?f=12
Reactions: slowcoach3
If its a PD engine I found out that machinemart do have them however don't know if they hold them in stock.
Thanks gent's that's awesome! Not worried about timing up when it comes to refitting just the taking it off in the first place, cheers
682
9
775
563
644
815
