Steering sitting slightly to the right on motorways
chrisinns17 Oct 23, 2013
  1. chrisinns17
    chrisinns17 Member
    Is anyone's new a3 steering wheel sitting slightly off centre especially on motorways ? These cars seem to be very camber sensitive ? Anyone else experiencing this ?
  2. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,378
    1,502
    Have you got 18" wheels?
  3. Daveotto
    Daveotto Well-Known Member Gold Supporter Team Sepang Audi S3
    2,676
    3,750
    18 inch s-line alloys on mine and have noticed this especially in dynamic mode, does not appear to be off centred tracking as goes either way depending on which road your are on and have put it down to combination of steering sensitivity and road camber, but have added to my minor niggle list along with wiper blade clash.
    If I find one more niggle will be time for first visit to the dealer service centre.
  4. chrisinns17
    chrisinns17 Member
    Yeap 18 inch sline model .. Wiper clash ??? Steering never looks straight .. Always sits slight off centre at speed .. A roads and motorways
  5. chrisinns17
    chrisinns17 Member
    Yeap 18 inch sline
  6. Daveotto
    2,676
    3,750
    thread is here http://www.audi-sport.net/vb/new-a3-8v-chassis/198461-windscreen-wiper-niggle.html
    right hand wiper blade clashes slightly with right hand pillar on upward stroke, only slight clash and does not warrant a dealer visit in its own right, so stacking them up!!
    seems like you fault might be more of a steering wheel alignment issue rather than drift due to sensitivity
  7. chrisinns17
    chrisinns17 Member
    At low town speeds steering is fine though
  8. chrisinns17
    chrisinns17 Member
    Yours sits slight off on motorways though ?
  9. Daveotto
    2,676
    3,750
    No, steering wheel sits square but car will slowly drift left or right when on a long straight section at motorway speeds and not holding the steering wheel with any amount of grip, not a bad drift but certainly noticeable compared to my previous 8P 1.4 TFSI SE, will get it checked out (eventually)just in case it,is an alignment issue. But if it is normal will be a small price to pay for the resulting more engaging drive you get form the car.
  10. cuke2u
    5,378
    1,502
    Do the 18" tyres/wheels combination suffer from tramlining?
  11. Toadoftoadhall
    Toadoftoadhall Active Member
    299
    80
    :ermm:
    Lane Assist would help with this issue!
    Daveotto likes this.
  12. chrisinns17
    chrisinns17 Member
    Just to redefine problem .. Cars steering sits fine when parked .. Seems fine when going around town .. Just when u get speed up and on motorways and a roads steering sits slightly off to the right .. Never looks straight the wheel .. Then slowing down wheel seems to look straight again .. With sline u get flat bottomed steering wheel so it gives u a line to level .. Maybe steering wheel lines not in line with dash lines ? Car does not pull or wander Just sits 5mm to the right at higher speeds
  13. cuke2u
    5,378
    1,502
    Hi, if any of the steering alignment was out I would have thought it wouldn't be selective to just a motorway though...
  14. Toadoftoadhall
    299
    80
    But if you then held the wheel dead straight and level it would drift slightly.
    I didnt notice this in the two S3s I drove (although they have the progressive steering so it may not be an accurate comparison) - but I would be off to the dealer with that issue.
  15. chrisinns17
    chrisinns17 Member
    Does anyone's new a3 steering sit perfectly straight ! On a motorway ? Please all double check and let me know .. No slight cantering to the right ???
  16. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,479
    1,124
    I'll let you know tomorrow...
  17. dieseldoug
    dieseldoug Member
    240
    53
    Sorry can't check on motorways as they are 100 miles away. But on dual carriageway car stays straight steering wheel okay also.
  18. dieseldoug
    dieseldoug Member
    240
    53
  19. dieseldoug
    dieseldoug Member
    240
    53
  20. Daveotto
    2,676
    3,750
    Heard you the first time!!!!
    Have checked different drive select modes on same section of road and mine occurs only in dynamic mode, really is only minor and I am surre it is just down to the drive select making the steering more sensitive.
  21. constvoid
    constvoid Active Member TFSI Owners Group Team Scuba Audi A3
    122
    29
    Yes I'm retty sure that's the case too - I only noticed it when I started driving in dynamic by default instead of auto. By coincidence this happened a few days before this thread started. i was a bit concerned until I found others had the same symptoms. I've now got used to it and it doesn't cause any problems.
  22. cemerson
    4,479
    1,124
    Not getting any of this I'm afraid - did a lot of motorway driving this weekend and didn't see anything like you are describing.
  23. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    Dave,
    Does this also happen in individual mode with steering set to dynamic?
    I haven't driven much in dynamic mode but live in individual mode & steering set to dynamic. Have not noticed the steering off-set.
    John.
  24. Furkz
    Furkz Active Member
    303
    its your wheel alignment, get it redone try and find someone with hunter equipment and make sure when you get it don't the green indicators are 100% straight up and car will drive fine. being within the tolerance levels does not ensure car will drive 100% straight
  25. Daveotto
    2,676
    3,750
    Have not tried individual mode, but will on way home assuming its not too windy to relax grip on the wheel.
    This is really a minor niggle and is my curiosity as to the root casue rather than someothing wrong with the car and as SL4VE states it might just be allignment being slightly out but in spec. I will however, get it looked at if i need to take the car in for something more significant
  26. RossR
    RossR Active Member
    501
    122
    43
    I noticed this a few days ago too. Tried it in comfort and dynamic - no difference. Doesn't seem to be camber related either. I'll check if I still get it on a 30mph road on the way home.
    I was thinking of taking it in to get adjusted. Now that I've noticed it, I can't forget it. It's interesting that we are all seeing it in the same direction. Must be a systematic fault - i.e. the jig or whatever they use in the factory is off.
  27. chrisinns17
    chrisinns17 Member
    Plays on your mind doesn't it ..
  28. chrisinns17
    chrisinns17 Member
    Car doesn't pull at all .. Just steering seems very slightly out of alignment ..
  29. Daveotto
    2,676
    3,750
    Are you sure you have not got a Stigmatism :whistle2:
    Seriosuly think we have two issues witihin this thread:
    1. A steering wheel straightness issue
    2. A wheel allignment issue at motorway speeds
  30. chrisinns17
    chrisinns17 Member
    Couldn't resist no more .. Booked in with dealer next Monday ..
  31. chrisinns17
    chrisinns17 Member
    So yours is doing the same ?
  32. Daveotto
    2,676
    3,750
    Only the second one for me - wheel alignment
  33. chrisinns17
    chrisinns17 Member
    Dealer adjusted tracking slightly .. Car is just very camber sensitive .. Wheel now straight until road camber takes over
