Hello everyone, the immobilizer is flashing on my car. Everytime I start the car it runs for a second and instantly dies.
My friend was able to retrieve the errors.
Does anyone know if the problem is related to Instrument cluster or ECU?
By the way it is a 2002 Audi A4 3.0liter V6 Quattro.
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 1213
Coding: 0001002
Shop #: WSC 05141 444 59564
VCID: 3C7C36AE4031B1FC
2 Faults Found
18265 - Load Signal: Error Message from ECU
P1857 - 003 - Mechanical Failure - Intermittent
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 003 - Mechanical Failure - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04497
Shop #: WSC 06435
VCID: 2648F4C6AEBD1B2C
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AH
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 00000
VCID: 67D6B9C26937C224
14 Faults Found
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01809 - Actuating Motor for Temperature Flap; Left (V158)
01810 - Actuating Motor for Temperature Flap; Right (V159)
01274 - Air Flow Flap Positioning Motor (V71)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
00532 - Supply Voltage B+
52-10 - Supply Voltage Too High - Intermittent
53-10 - Supply Voltage Too Low - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
00474 - Control Module for Immobilizer
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00000
VCID: 346C1E8E686179BC
4 Faults Found
01518 - Bulb for Back-Up Lights; Left (M16)
57-00 - Electric Circuit Failure
00988 - Lamp for Brake Light; Right (M10)
01493 - Bulb for Blinkers; Front Left (M5)
35-00 - -
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 01141
Shop #: WSC 00000
3 Faults Found
127-10 - Unknown Error Elaboration - Intermittent
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D25
Coding: 03243
Shop #: WSC 43169
VCID: 2E580CE6864D536C
WAULT68E52A142099 AUZ6Z0A0251508
4 Faults Found
01039 - Coolant Temperature Sensor (G2)
01177 - Engine Control Unit
65-10 - Unauthorized - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00002
Shop #: WSC 63351
VCID: F1E2579AD7F38C94
7 Faults Found
00668 - Supply Voltage Terminal 30
06-10 - Signal too High - Intermittent
01336 - Data Bus for Comfort System
01330 - Central Control Module for Central Convenience (J393)
79-00 - Please Check Fault Codes
35-00 - -
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
20-00 - Malfunction in Basic Setting
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
VCID: 356A238A631B60B4
3 Faults Found
00625 - Vehicle Speed Signal
03-00 - No Signal
65535 - Internal Control Module Memory Error
00-00 - -
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0617
Coding: 28220
Shop #: WSC 05141
VCID: 4280485622D5C70C
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
19 Faults Found
01333 - Door Control Module; Rear Left (J388)
01581 - Incorrect Component Detected
35-00 - -
01134 - Alarm Horn (H12)
28-10 - Short to Plus - Intermittent
29-00 - Short to Ground
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01803 - Door Warning Lamp; Rear Left (W37)
57-10 - Electric Circuit Failure - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01334 - Door Control Module; Rear Right (J389)
01562 - Right Rear Door
59-00 - Can't Unlock
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 A
Component: symphony II NP2 0050
Coding: 00211
Shop #: WSC 00000
VCID: 254AF3CAD3BB1034
5 Faults Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
00466 - Control Module for Steering Column Electronics (J527)
01300 - Control Module for Navigation with CD-Rom (J401)
End ---------------------------------------------------------------------
Coding: 0001002
2 Faults Found
Coding: 04497
Shop #: WSC 06435
1 Fault Found
35-00 - -
Coding: 00000
Shop #: WSC 00000
14 Faults Found
35-00 - -
Coding: 00001
Shop #: WSC 00000
4 Faults Found
35-00 - -
Coding: 01141
Shop #: WSC 00000
3 Faults Found
35-00 - -
Coding: 03243
Shop #: WSC 43169
4 Faults Found
01304 - Radio
Coding: 00002
Shop #: WSC 63351
7 Faults Found
35-00 - -
3 Faults Found
03-00 - No Signal
00-00 - -
Coding: 28220
Shop #: WSC 05141
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
19 Faults Found
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00211
Shop #: WSC 00000
5 Faults Found
