st/st exhaust systems A4 Quattro Avant 2000
Iceash Mar 26, 2012
  1. Iceash
    Iceash Member
    391
    10
    Hi All,
    Going to need a new exhaust at some point soon, want to go stainless, but not spend too much. Where should I be looking?
    thanks,
    Ash
  2. Sulli79
    Sulli79 Active Member
    541
    37
    How much is your budget? I'll be going for a miltek as soon as I get the funds together, About £600.
  3. Iceash
    Iceash Member
    391
    10
    yikes! as near as £300 as poss, something quiet. Just want it to last really, doesn't even have to be performance.
  4. aragorn
    18,186
    770
    Unfortunately there arent many options bar the overpriced miltek mentioned above.
    I'd suggest you find a local exhaust fabricator thats well respected, and have them build a system to your specifications.
  5. Iceash
    Iceash Member
    391
    10
    Other than powerflow, know any other national fitters?
  6. Bradderz_1988
    3,949
    235
    Topgear longlife exhausts theres one in stockport and a few others in the uk.
  7. aragorn
    18,186
    770
    The problem with national chains is they're all franchises and as such are hit and miss.
    Just because someone had a good experience in Top Gear Stockport, doesnt mean the one near you will be any good.
    You really need to find recommendations in your area by speaking to folk from around there.
  8. dubster67
    dubster67 Member
    152
    9
    Are saloon quattro exhausts the same as avant, if so then I got a Jetex exhaust for my TQS. Abit louder than standard, but not annoying.
    Fitted not too bad either, and it was cheaper than a Miltek. About £390 from C&R Enterprises.
  9. aragorn
    18,186
    770
    yeh they're the same
  10. Iceash
    Iceash Member
    391
    10
    Thanks for all the replies guys.
  11. Mackers
    Mackers Member
    291
    what about the 2.5 tdi, they the same as any other model.
    (sorry for partially hi-jacking)
    wayne
  12. aragorn
    18,186
    770
    similar to a V6/S4 but not exactly the same i'd say.
    You could use a S4 system, but would probably need to tweak the link pipes between the downpipes/cats and the new exhaust.
  13. hardhitter
    hardhitter Member
    138
    Got any photos of it fitted (better still a vid :icon_thumright:) ? Seen them at C&R and they look pretty good !
  14. dubster67
    dubster67 Member
    152
    9
    I'll get some photos as soon as I can - the exhaust system is currently off the car as I am rebuilding the rear suspension.
  15. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I have a standard TQS mid to back system sitting in the corner if you want it! was a chap on here going to take it off my hands for some beer money but he changed his plan
  16. Iceash
    Iceash Member
    391
    10
    I got a quote from long life. £390 I didn't think that was bad?
