Sportback a3 2009 door trim removal
Linard18 Mar 3, 2012
  1. Linard18
    Linard18 New Member
    Really appreciate some help to tell me how to remove my door trim on my Audi a3 2009 sportback?..
  2. AndyMac
    9,832
    45
  3. NHN
    29,284
    1,695
    Also is it the door card or the piano black/alum trim that you're referring to, you really need to expand on your request more when asking for help, otherwise info supplied could be wrong.
  4. h18srw
    h18srw New Member
    9
    any ideas how to remove the window switch from the door arm, i cant find this anywhere, it seems the cover just need to be rmeoved from the door arm but I dont know how confident to be in just tearing it off as it seems the clips are going to break and they dont look like replaceable ones,
  5. Cooperuk
    Cooperuk New Member
    22
    Use something like a credit card to lever it off.
  6. NHN
    29,284
    1,695
    You need to remove the door card & then the arm then you will have access to it.
    Not a chance.
    h18srw likes this.
  7. Rob2k68
    Rob2k68 Well-Known Member Team Daytona quattro Audi S3 DSG
    5,967
    8,936
    Hi there, does anyone have a guide or link to remove the inner door trim (front door) of an 09 sport back ? - it is different to the guide shown in post 2 and has the chrome strip running almost horizontal from the door release pull to the rear edge of the trim. Just bought the later window and mirror switches to fit so hope it's dry at the weekend.
    Thanks all.
  8. Cooperuk
    Cooperuk New Member
    22
    My apols - Thought he needed to take off the switch cover. You need to remove the entire door card and get happy with a screwdriver to remove the actual switch unit.
  9. Rob2k68
    5,967
    8,936
    I'm guessing that the door structure and mechanical fixings are the same so the hidden fixing is behind the piece of trim in front of the release handle that houses the global lock switch on drivers side and just a blank piece of trim on passengers side ?
  10. Ash187
    7,444
    704
    h18srw likes this.
  11. h18srw
    h18srw New Member
    9
    door card off, and access to door arm from the back.. result!!
    any suggestions for genuine audi parts by part number as im going to replace the arm while im at it
  12. NHN
    29,284
    1,695
    Yeah, Audi would be a good start :)
  13. h18srw
    h18srw New Member
    9
    yea alrite, take it easy
    all joking aside, they ended up cheaper than the breaker yard for 3 of the parts, go figure. switch from audi £24.00, switch from braker yards and ebay same...go for a hike
    audi did want £60 to replace the arm cover, this I found on ebay for £15.
    should be back in action by thrs once it all arrives
    cheers
