S-Line is 20mm lower than the SE, so if the SE has been fitted with oem spring's and damper's than yes. If the SE has after market suspension the car maybe a little lower.,
I have an SE with OEM Sports Suspension Fitted and the answer to your question is YES it has the same height as the S Line.I know this because I have compared it with a colleagues S Line. It is at least 20mm lower than the standard supsension ( and looks more when at the side of a standard SE ).
