smoke from exhaust even when warm
drewbee Feb 22, 2010
  1. drewbee
    drewbee Member
    196
    hi guys, I've noticed that smoke id always coming out of the pipes and is very noticable in my mirrors, even when warmed up. should I be worried? or is this normal?
    its had a full service about a month ago.
    thanks
  2. paul20v
    paul20v Audi fanatic
    1,113
    What colour ?
    is it steam (white )
    oil (blue)
    grey (fuel)
    are you losing water or gaining oil
    is there anything in the water residue of oil etc ?
  3. drewbee
    drewbee Member
    196
    its just white steam, i can see it in my side mirrors.
    tell me its nothing to worry about.....
    but im pretty sure when cars are warmed up, there shouldnt be smoke??
    cheers
  4. quattrojames
    14,050
    575
    Generally I'd agree with you, but bear in mind (around here at least) the air is cold and damp which will compound the effect of any condensation.
    Perhaps just be slightly more aware of the symptoms of head gasket failure until you've had the opportunity to reassure yourself ;)
  5. simon.m
    simon.m Active Member
    2,747
    i see cars every morning that do that loads of white smoke evan my tdi dose it its cold out there mate.
    i had a head gasket go on my last car and did not no as it was not oil mixing with water so was not getting the sluge on dipstick.
    but lost heat in the car and was using a lot of water like one L on a 20 min drive if its that your top rad hose will be rock hard but
    to be safe pop it into any garage thay have a test they do it should be free but id say its nothing to worry about.
    i had smoke from mine when the temp sensor was faulty and not the good kind but that was the temp sensor.
  6. Mike B
    Mike B Well-Known Member
    1,101
    40
    Lots of white water vapour from my 2.5 TDI onthese cold damp days seems to be more on these than other cars but it should go when warmer and check oil and water levels regularly.
  7. golf
    golf ***** rent boy VCDS Map User
    1,556
    It's just because of the cold weather and damp air which causes condensation, and in turn makes it look like the car is smoking. It'll be nothing to worry about, I see a lot of cars (mainly powerful big engined) pushing out lots of steam in traffic jams.
  8. paul20v
    1,113
    Yes but it should go when the engines hot and the cars on the move you should not notice it .
  9. golf
    1,556
    I would assume he's only really seeing this in traffic or at low speeds. drewbee correct me if I'm wrong?
  10. paul20v
    1,113
    What is it they say ? are yes
    Assumption is the mother of all fuckups
    :laugh::laugh::laugh:
