mikerajjers
- Joined
- Jan 16, 2015
- Messages
- 34
- Reaction score
- 2
- Points
- 8
Hi all,
just a bit of background info first. Bought by 1.8T cabriolet back in Jan. Since then spent a small fortune getting it right (MAF, lambdas, engine mounts, brake pads, fixing massive oil leak due to dodgy rocker cover gasket, sparks, injector seals, boost valve) and now the engine is running well.
My main issue now is a 'sweet' smell in the cabin, which I can smell only when stationary, but not always, only sometimes. I had a petrol smell a few weeks back but that is gone since replacing injector seals. I'm well and truly stumped as to what it could be and whether I'm beginning to imagine things? I'm beginning to think it could be a dodgy filter somewhere, perhaps pollen? Or perhaps the aircon needs a good clean?
I thought it could be coolant leaking somewhere as I had quite a low level, which I topped up. But smelling the coolant from the bottle, it doesn't match the cabin smell. I thought it could be the heater system somewhere, but it is very intermittent and I parked it in my drive just now, engine running and could not smell it (even when putting the fans on max). Opened the bonnet and couldn't smell it either. Peeled back the plastic near the battery and no smell either. Also no obvious signs of any leaks anywhere.
As I couldn't smell it whilst stationary on driveway (engine running) but only when in town, I'm now thinking I may have been smelling fumes from outside. But surely there should be a filter somewhere?
Could it really be just an issue with a pollen filter and the aircon system needing a professional clean? What would you recommend checking?
Sorry for long winded post.
Thanks in advance
Thanks in advance
