Single or double din socket ????
lake_m Dec 3, 2009
  1. lake_m
    lake_m Soon to be S3'd up.
    62
    Considering a RNS-E retro install later on. Apparently it makes a big difference to the complexity of the job depending on whether you have a single or double din connector in the back of the existing radio.
    The question is are all new S3's double din or does it vary depending on what radio you spec (concert or synphony?)
    Sorry if this has been asked before.:uhm:
  2. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    "Double Din" is one thing...
    "Socket" is another.
    Double din refers to the OPENING; in other words the HOLE that the bloody thing fits into. -If that hole is the wrong size, you're going to have to do a LOT of work. (hint: search double-DIN conversion)
    The socket is going to be either Quadlock or ISO. A small, inexpensive adaptor cable, and ten seconds to plug it in.
    the Socket is easy-peasy, lemon-squeezy, Japaneezy rice-and-cheesy, yo.
    Keith
  3. Broken Byzan
    13,237
    465
    The conversion is made easier if yopu have the double DIN HU already as you won't need to change the console then. What HU do you have fitted?
  4. lake_m
    62
    I don't have the car yet. Just wondered what comes as standard on a new S3 with synphony radio fitted? Sorry for the confusion.
  5. s8craig
    1,753
    56
    All new S3's have double din radio's wether they be concert II+ or symphony II+.
  6. lake_m
    62
    Cheers mate, That's what I needed to know. :thumbsup:
  7. lake_m
    62
    Cheers Keith - I was thinking it was the connector (not the flammin' hole in the console!) :keule:
  8. VWAddict
    656
    9
    Yep.
    If it's a new one, it will not only Be Double-DIN, but also have the 'quadlock' conector which mates directly with the RNS-E.
    A little programming with VAG-COM, one wire to relocate if you have Bose (ignore this step if you don't have Bose) and you're pretty much rockin.
    Oh, £10 worth of antenna (if you don't have the sharkfin) or quickly run a FAKRA extension (if you DO have the sharkfin) is the only other thing to do.
    Swapping the head unit over took me 5 minutes beginning to end. Programming with VAG-COM took 10 minutes with a leisurely cup of PG tips and a smile. I have the Sharkfin, but I still just plugged in the in-dash antenna instead... did it while the head unit was out, took 20 seconds, stuck it to a metal bracket (it's magenetic, further secured with a cable tie) and the whole thing was 15 minutes.
    The rear antenna diversity system is different, but unless you're in a VERY weak reception area, it's just fine. I drove to Fort Lauderdale and back on Tuesday including driving through some fairly isolated parts, and I was able to get dozens of stations at all times.
    If you're getting a new one, it'll be a doddle. If you have a VAG-COM it'll be under 15 minutes. If you Don't have a VAG-COM, either take this as the opportunity to buy one (Highly recommended!), or find a friendly local who DEOS have one, and ply him with Old Speckled Hen, Guinness, or whatever.
    Doddle. -Good luck!
    Keith
  9. lake_m
    62
    Excellent. What antenna did you use (and where did you get it?)
    Thanks for the reply - it's sounds like a deffo DIY job.
    PS - Is the programming just a case of activating the necessay features (e.g. I'll have the bluetooth module from new so will like that integrated if possible)
    Now, just need to get hold of a VAG-COM :beerchug:
    Andy.
