Side turn signal lights
L333fow May 19, 2013
  1. L333fow
    L333fow Member
    66
    Hi all,
    I've just noticed that neither of my side turn signals are working (ones on wings)
    ive check vcds and all seems fine the option for side turn signals is on!
    now I don't actually know of these have ever worked!
    ive also checked bulbs
    its a 2007 a3 2.0tdi sline sportback
    cheers
  2. NHN
    29,284
    1,695
    Module 09, byte 22, bit 4 where there’s an option for Speed Dependent Trunk Locking Active, make sure this isn't enabled.
  3. L333fow
    L333fow Member
    66
    Got rather excited then that I may eventually have an answer as it was enabled but after un-ticking it still no joy
  4. NHN
    29,284
    1,695
    Have you done a lock/unlock then test again as sometimes needs a reset, plus check bulbs, show us a log of module 09.
  5. L333fow
    L333fow Member
    66
    Yup tried that, I have however just noticed that when I unlock the car and the leaving home lights come on so do the side turns!
    How do I log modual 9?
  6. L333fow
    L333fow Member
    66
    Actually just double checked and only the drivers side lights when I unlock!
    ive taken a screen shot of the coding but can't seem to upload! Also in the measuring block under side turn it just has a dash!
  7. NHN
    29,284
    1,695
    Just show us the coding for module 09, screen dump of your pc when logged into module is good enough, hopefully.
