Seat height adjust not working
Searider Oct 24, 2013
  1. Searider
    Searider Member
    32
    Evening all,
    The electric height adjust on my drivers seat has just stopped working.
    When switching it up and down there is a clunk - but the seat doesn't move.
    Is this common?
    I guess I'll have to take the seat out and investigate - is this just a case of unbolting the rails from the floor pan and the electrical plug?
    cheers
    Duncan
  2. Bigandbald
    Bigandbald Member
    105
    31
    Hi Duncan,
    if you do a search for rector not working or something similar there is a post on how to fix from memory
  3. Searider
    Searider Member
    32
    Cheers, will do.
  4. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,777
    613
    they're easy to whip out if you need to, take the trim off the back of the rails, cant remember how to get the inside trim off, i broke all the clips on mine :/
    outside trim has 1 screw in the middle which is covered by a cap then will pop out
    undo the 2 bolts at the front
    pop the seat back a bit
    you should have decent access to get to anything you need to now just by tilting the seat back, if you need it right out just disconnect the electrics (2 plugs) then shove the seat right back out of the rails and lift out
  5. Kuvi-S3
    Kuvi-S3 Active Member
    175
    49
    I had the same problem with mine a few months back. There a tiny switch on the seat. Just needs to pressed to restet and the adjustment works again.
  6. jcs356
    jcs356 Brum brum
    2,723
    64
  7. Searider
    Searider Member
    32
    Hi Kuvi,
    where was the switch?
    duncan
